18B900 and 18B800 codes
Old Apr 25, 2019 | 07:14 PM
Potrice's Avatar
2013 ML350 Bluetec, 1966 Ford Mustang Convertible (sold)
Well if you've been following my previous thread, you'll know that my brother in law's 2013 ML350 BT had codes for the NOx sensors. I installed new NOx sensors (the one upstream and the one downstream) and cleared the codes. Well, they came back so he took them to an indy shop and the shop (using their Xentry/Star machine) diagnosed the 2 codes as 18B900 and 18B800. So the indy shop readapted/reprogrammed the 2 NOx sensors. After about an hour of driving, the codes came back! What is going on here? Wiring issue?
Old Oct 10, 2019 | 12:37 PM
Etienne Lau's Avatar
Ml350 bluetec
Did you ever get this resolved? My BT is throwing up the exact same codes as well.
Old Feb 8, 2022 | 11:21 AM
mistrykr's Avatar
ML350
do you have any update on your issue? How did you get it to fix? I am having same 2 codes.
Old Feb 8, 2022 | 11:24 AM
Potrice's Avatar
Never found out exactly how to fix it because the SUV had a full delete afterwards... If anyone finds a solution, feel free to post it here.
Old Feb 8, 2022 | 02:03 PM
Ml350 bluetec
I took it into the dealer, I had an extended warranty and it was covered. But I believe with the AEM that is rolling out, this will now be covered by the AEM as well.
Old Feb 8, 2022 | 03:45 PM
mistrykr's Avatar
ML350
Thank you for your response. What is AEM?
Old Feb 8, 2022 | 05:02 PM
Ml350 bluetec
The recent mandated Diesel Update to meet EPA requirements. They were required to make all kinds of updates: DPF, NOX Sensors, DEF sensors, Catalytic Converter, etc.....Depending on the vehicle some or all of those parts got changed. If yours includes the NOX sensors then the NOX sensor replacements will fix the issue.
When I took it in, they basically replaced replaced and re-coded the NOX sensors. And charged it all to my extended warranty.
Old Feb 9, 2022 | 12:18 PM
zemun1234's Avatar
2005 E320 CDI (sold); 2007 R320 CDI (sold); 2008 ML320 CDI; 2014 ML350 Bluetec
I am wondering if MB provided list what they changed on your car. I am not sure that AEM modification could make car same as before. It would be helpful if we (in Canada) could get more information ...
Old Feb 9, 2022 | 02:22 PM
mistrykr's Avatar
ML350
I found this online.. sample letter that you'll receive from Mercedes Canada once field measurement test is available for your vehicle. Read 'what will your dealer do?" section.
found this
