Command system replacement.
Old Sep 9, 2019 | 07:27 PM
Roland Goering's Avatar
2014 ML350 BlueTec 4Matic
I was wondering if someone could tell me when replacing the command system with an aftermarket head unit do you lose all of the system screens of the old unit?
Old Sep 9, 2019 | 09:22 PM
geniushanbiao's Avatar
2012 ML350 Bluetec, 2015 GL350 Bluetec
I honestly don't think you ever need to replace the head unit. There are android powered screens sold on ebay and aliexpress that can couple with the factory command unit. They are about $500-600 but you can choose to use android or use the NTG mode.
Old Feb 20, 2020 | 02:41 PM
Diamondrichlb's Avatar
2022 GLC 300
In my experience with 2 of the AVIN units, you do not lose all, but you do lose some and/or they don’t work as before. There is a place in setup where you can define the buttons in the new unit, but without adequate instruction, I have not used those settings.
Old Feb 20, 2020 | 03:41 PM
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
You lose nothing if you do the install of an Android unit properly.
Old Feb 20, 2020 | 03:50 PM
2022 GLC 300
Cool. I would really like to know how that is done. Care to share?
Old Feb 20, 2020 | 03:56 PM
we47b1me's Avatar
https://www.incarpassion.com/install...id-navigation/
Old Feb 20, 2020 | 04:29 PM
I did the installation. You lose nothing unless you break any. The Android system replaces the old screen and it gets power through a pass-through plug placed between the command unit and its main plug. The Android system has its own antennas and the sound output goes to the AUX port, which you need to route the cable to the glove box. The Android system has NTG mode if you put it in this mode it would be EXACTLY THE SAME as the factory unit except that the screen is larger which makes the display a little blurry. Otherwise if you put the command system audio input as AUX you can enjoy the benefits of the Android system. The Android system can also work with a 360 camera if your vehicle doesn't have one, just need a lot of work to install.
Old Feb 20, 2020 | 10:22 PM
2022 GLC 300
Ah, I thought the question was regarding the dash board readouts, which in my installations have been less robust then the OEM Command Unit. As far as the unit itself the display is superior. And the new CarPlay dongle works really well.
Old Jul 9, 2024 | 12:32 PM
mkhleung's Avatar
2010 C300 4Matic Sport (Canada)
Sorry please ignore this. IT was posted in the incorrect forum and I'm not sure how to delete my post.
