How many miles are to many for a used W166?
I've been looking for an ML350 with less than 60k miles for several months and yesterday I saw one with 85k miles. Normally I wouldn't be interested in it but it has real leather, premium sound and the HID light package. So should I be concerned about buying one with 85k miles?
It doesn't look like the transfer case fluid has been changed and when I was talking with a service writer with my local MB dealer he said MB recently changed the interval on the transfer case to 30k miles which is why I'm a little concerned. I've seen a few threads about the transfer case chain guide breaking but the two indy shops I called said transfer case failures were pretty rare on the W166. They both said that with proper maintenance the W166 was pretty bullet proof, which I found encouraging.
The maintenance history, according to CarFax, is okay with annual oil changes. One of the oil changes was greater than 12k miles, three were between 11k and 12k miles and 4 were less than 9k. All of the oil changes were done by a MB dealer and I was wondering if the intervals are anything to be worried about?
The spark plugs were changed at 60k but CarFax doesn't show anything about the transmission fluid being changed. I plan on calling to MB dealer to ask them if the trans was done at 60k. The flex plate was done at 70k.
It doesn't have the adaptive suspension or the tow package so how long do the struts and shocks typically last and how difficult are they to replace?
It's located in a rust belt state and I was wondering if any of the northern members could chime in on whether or not I need to be worried about body rust? I looked at autotrader.ca in Montreal and Toronto and none the ML350's I saw online had any body rust which I found encouraging but local perspectives are definitely welcome.
Thanks in advance for any help and/or opinions you guys can provide, I really do appreciate it.
Because it was introduced in 2012, mileage for W166s in the 150k miles range is still uncommon. I don't recall reading any 200k mile reports for a W166.
I wouldn't be concerned with the oil change interval scenario you mentioned.
As far as struts, or shocks, for non-air suspension, my experience with a VW is that they did not need to be replaced well beyond 200k miles. My 238k mile Touareg had factory shocks on it when I sold it back to VW. Sure, new shocks would have been nice, but they were not required. I will not be surprised if the W166 is similar to the VW in this regard.
In summary, the W166 is a robust platform. Ultra high mileage still remains to be seen, only because of the relative newness of the platform.
It's nice to hear you confirm that the W166 is a robust platform and that I probably won't need shocks and struts at 100k miles. Thanks again.
Unfortunately 2013 is the newest year that's within budget for me. Hopefully the 2012-13's will be good to 200,000+ as well.
I've always been good at over maintaining so following the recommended service schedule shouldn't be a problem for me. I do a good job of keeping my car clean but next year I'm probably going to be moving to a rust belt state. That's the reason I asked about body rust. It's good to hear that it shouldn't be an issue.
I had a creaking sound going over speed bumps which was fixed after replacing the UCAs.
Other than the rattle sound, no other issues with my ML350 at 130K miles.
It's good to hear that the UCAs were the only problem you've had. Them and the ball joints are kind of a normal wear and tear item so those won't bother me to much.
Unfortunately the dealer that has the one I was looking at decided to play games with the price so I have moved on. It would be a lot easier to find one if I hadn't decided that 810 - Premium Sound is a requirement.
Thanks again
Thanks for the timing chain tensioner warning. I ran across the TSB for it not long after I started researching the W166s. I called my local MB dealer and a couple of indy shops that specialize in MBs and they all said the startup rattle was more of an annoyance than an actual cause for concern. Definitely not worth spending the money to have the TSB taken care of now that the one's I'm looking at are out of warranty. I've looked at the Carfax for a lot of W166s and I have to see one that had the TSB taken care of under warranty.
Thanks again
i bought a `13 4Mati with 53k miles 2.5 years ago and have 145k miles on him now. Absolutely no issues, A and B services regularly at the dealer, and going strong. We're about to head out on another 2500 mi road trip, and i'm not worried a bit. Just be thurough in your research and get the carfax.
I always look at the Carfax to see what the maintenance history looks like and I also look at the data card to check for the HK sound system before I even call the dealer. I think the combination of the two is the reason I haven't bought one yet.
This month is has covered 4k and will do another 2K this week and I won't even check the tyres (that the correct spelling)
I still prefer my old W163 but this isn't all bad.
I'd buy another.
It sounds like you might be in Canada. If you are have you noticed any W166's with body rust?
Thanks again.
Sorry for late reply.
I'm in Sydney Australia. We don't much rust down here but plenty of bad roads.
My car has never been kept out of the weather so its been exposed for 6 years and still looks like new..
After 250,00klm (150,000 miles for those stuck in the Imperial system) in a W163 I swapped to a W166 gas.
Its having a 90,000KLm service (55,000 miles for only place in the World, other than Myanmar, to use the Imperial system).
So far it needs one engine mount, new Spark Plugs, Sway bay ends, and new plug leads.
Funny thing is I gave my old W163 to my Mechanic as a shop car and I may end up driving it again as my car may be off the road for a few days. I won't use Mercedes as my local Dealer is a scumbag.
The cost of an A service has blown out to around $2,000 Aussie Dollars or 1,400US Dollars.
Still like the W166 and don't care about the cost but I still love my old W163.
Sort of like a well endowed Girlfriend who got away!
