2014 ML350
Old Feb 21, 2020 | 08:36 PM
albanian111's Avatar
2014 e250 bluetec
2014 ML350
Hey yall, just purchased a used 14' ML350 bluetec
Any long time owners of these bad boys?
I just did an oil change at the benz dealer and the oil is black, not sure if that's normal.
Any input would help
Old Feb 21, 2020 | 09:12 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the ML.
Old Feb 21, 2020 | 09:17 PM
2014 e250 bluetec
Here she is, amazing condition in and out
Old Feb 21, 2020 | 11:03 PM
chassis's Avatar
2017 GLE350 4MATIC
Looks great!
Old Feb 22, 2020 | 04:42 PM
Kartergreg's Avatar
2013 ML350 Bluetec, 2016 C3, 2020 Lincoln Aviator
I have a 2013 ML350 bluetec. Love it. It's a diesel so of course the oil turns black within just a few miles of driving even right after an oil change. Oil leaks from the oil cooler seals is a known issue and an expensive repair. Mine went in today for the oil leak issue, but lucky for me I have the extended warranty. Exhaust sensor failure and DEF pump failure are some other issues to be aware of.
These vehicles are very sensative to the type of oil used and using the wrong oil will poison the particulate filter. Several folks have reported that even the dealers occasionally use the wrong oil and that's one reason I change my own.
Old Feb 22, 2020 | 04:49 PM
2014 e250 bluetec
thank you for the reply man, glad youre enjoying it. I actually did research on the emissions stuff and I think I'm going to go ahead with the delete (egr def,adlue) but the mechanic said to not touch the DPF because then the car will sound like a tractor and it will smell. He told me as long as I delete the other stuff, it should be pretty solid after that. Any input on this ?
Old Feb 22, 2020 | 04:59 PM
Kartergreg's Avatar
Yes, I'd probably do the delete too if it were not illegal.
That is the 3.0 V-6, correct? At some point they switched to a 4 cyl diesel.
Old Feb 22, 2020 | 07:16 PM
GLK Super Fan's Avatar
GLK250 ML350
The 4 cyl diesel W166 never make it to North America
Old Feb 22, 2020 | 07:18 PM
2014 e250 bluetec
hey buddy I've seen your posts about the delete. How is your GLK ?
Old Feb 22, 2020 | 08:59 PM
Kartergreg's Avatar
2015 ML250 bluetec 4cyl diesel.
Old Feb 22, 2020 | 09:09 PM
excal's Avatar
W166
ML250 was sold in USA, but not Canada.
Old Feb 22, 2020 | 09:59 PM
GLK250 ML350
Wow so jealous. That will be a good one to keep. Now i want to get one from US. Om651 is a damn reliable engine
Old Feb 22, 2020 | 10:05 PM
GLK250 ML350
I had delete done on both my glk and ml. Both vehicles are still running really strong. Best decision ever made. If you live where does not require emission test, get the delete done, then u will feel the true power of diesel. For example, i can spin all 4 my tires of my ml when I kick down at stop. I guess that what 500 ft pounds of torque can do
Old Feb 22, 2020 | 10:38 PM
2014 e250 bluetec
Awesome man!!! I seen on your posts that your from Calgary, so I'm I man!! I called and talked to the ecu program guy and he told me to do the first phase delete first (egr, adlue, def and that stuff). He said to leave the DPF in place for now and to not disturb it unless it gives issues then to remove. Did you fo it all or did you only do the first phase delete and left the dpf attached ?
Old Feb 22, 2020 | 11:42 PM
GLK250 ML350
I did the stage 2 because i don't want to go back to the shop if I don't have to due to where i live. Plus the price difference are very minimal, and you can get a lot more power when you do the full delete. If you live very close, u can definitely listen to Sam, since he is a pro when it comes to tuning.
Old Feb 23, 2020 | 01:59 AM
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
not true at all -- the om651 is in the ML250 and was available for one year -- 2015.
I know. I have one.
Old Feb 23, 2020 | 05:48 AM
Kartergreg's Avatar
I know. I have one.
Had no idea USA was not considered part of North America.
Old Feb 23, 2020 | 11:37 AM
2014 e250 bluetec
I live in Calgary so shouldn't be a problem to go see Sam. I heard though that if you do the full delete that the engine is very noisy and theres alot of smell? Is that true
Old Feb 23, 2020 | 01:24 PM
GLK250 ML350
My bad. I made an incorrect statement
Old Feb 23, 2020 | 01:26 PM
GLK250 ML350
Didn't notice too much noise different. In terms of smell, yes u will smell the diesel, special if you standing behind the exhaust. But not bad overall. I don't mind it. I had both my vehicle done. You cant smell it once you start driving the vehicle
Old Feb 23, 2020 | 02:09 PM
2014 e250 bluetec
I dont care about smelling it when I'm outside the vehicle, I'm worried about smelling it In the cabin. I'm not sure if you smell it inside or no?
Old Feb 23, 2020 | 02:14 PM
GLK250 ML350
No for 95 percent of time. The only time u can smell it the odd time is when u sit in traffic and the wind is blowing at the exhaust direction, you can smell a bit, but not horrible. If you want, send me a pm, next time i am in Calgary. I can let u hear it, smell it lol
Old Feb 23, 2020 | 03:21 PM
2014 e250 bluetec
Lol sounds good man I will
