2013 ML350 Bluetech Rough Idle
Old Aug 4, 2020 | 10:59 PM
cl500 probs's Avatar
2003 CL500
Thank you in advance for taking the time to read this post.
I have a 2013 ML350 Bluetech with 100k miles that is rough idling. I live in Michigan and it started it by only rough idling in cold weather.
Now it rough idles all the time, even in summer. Check engine light is on and this the current active code.
10e300 " The number of combustion misfires at cylinder (0) is too high.
Is this a bad fuel injector ? What should start with?
Again any help is appreciated, thank you !
Old Aug 4, 2020 | 11:53 PM
GLK Super Fan's Avatar
GLK250 ML350
I think ur injectors are leaking! It happened to my glk250 BlueTEC.
Old Aug 4, 2020 | 11:55 PM
GLK250 ML350
Do you have a good independent mechanic? The injector set are expansive, just the parts alone is 3k usd plus labor, you are probably looking for 3.5 to 4k repair
Old Aug 4, 2020 | 11:59 PM
GLK250 ML350
https://www.fcpeuro.com/Mercedes~Ben...words=injector
3.1k for parts if you want to replace all of them
Or replace one and trade the vehicle in
Old Aug 7, 2020 | 11:26 PM
2003 CL500
Oh boy....
Could it be glow plugs? Or anything else I can check first before jumping off a cliff... Haha
Anything I can check before spending so much money on fuel injectors?
Old Aug 9, 2020 | 02:26 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
I guess I'm running out to buy a case of injector cleaner......
Old Aug 9, 2020 | 08:27 PM
GLK250 ML350
Oh boy....
It shouldn't be your glow plugs unless you have a start up issue.
At this point, i will pay a good mechanic to do a proper diagnosis on whats wrong in your vehicle. Do not go to dealership! Find a good mechanic willing to work with you.
Old Aug 10, 2020 | 05:24 PM
Chamelleon's Avatar
ML500, ML350 BT, GLE 400
Clean the injectors first my friend and don’t spend money away.
Old Aug 11, 2020 | 08:26 AM
2003 CL500
Would cleaning them work? I'll look online to find a video how to do that, is there a video you recommend?
I've always have the impression fuel injectors can be tricky work, but I have removed and put them in a BMW gas
Old Aug 11, 2020 | 10:52 AM
GLK250 ML350
You can try to clean them, I did it with my GLK before. Eventually, the rough idle just got so bad and smoke like crazy during cold start up. I did asked my mechanic what happen if you I choose to ignore the problem and continued with the leak injectors. He told me there are chance the the engine will get flooded and sized due to excessive amount of fuel. In addition, google OM642 black death, you will see it a common problem for our engine to have a leaky injectors. Did you find a mechanic to take a look at your vehicle yet ? Once you open up your engine, you should easily see if there are any carbon build up around the injectors. If there is, you better get that taken care soon than later before it ends up to black death OM642.
