2013 W166 - strong ammonia smell
Old Nov 18, 2020 | 11:51 PM
boomie's Avatar
W166 ML350 Blutech
I've searched all over this forum and others, but haven't been able to find a concreate answer.
I have a very strong ammonia smell coming from the car. I only notice it when the car is idle - such as parking the car in the garage, then exiting. It's blowing a thick white smoke from the driver side. The strong is overwhelming.
I've read Ad Blue Temp Sensor, Nox Sensors etc.
On a side note, I'm in Canada and received a voluntary warranty extension re: soot particulate sensor. Big words that mean nothing to me.
Does anyone know what's going on? Is the issue related to the voluntary warranty extension?
My SUV is a 2013 W166 Bluetec with 153,000 km.
Old Nov 19, 2020 | 08:25 PM
chassis's Avatar
2017 GLE350 4MATIC
You are smelling DEF, which is urea diluted with water. Sounds like you are experiencing a problem with the DEF system. Did you scan for stored and active codes? Do you have any warning lights illuminated?
Old Nov 23, 2020 | 11:05 PM
boomie's Avatar
W166 ML350 Blutech
Code was for the soot particulate sensor. It was replaced under the voluntary extended warranty!
smell is gone.
Old Nov 24, 2020 | 01:44 PM
Chamelleon's Avatar
ML500, ML350 BT, GLE 400
Hey Boomie.
What part of Canada are you located in?
I've experienced the same issues last fall when the outside temperatures dropped down.
The heater went bad and I was losing DEF fluid, also my EGR valve got stuck.
Solved by deleting EGR, DEF, and swirl motors.
Old Nov 24, 2020 | 07:31 PM
boomie's Avatar
W166 ML350 Blutech
Originally Posted by Chamelleon
Hey Boomie.
I’m in Toronto!
umm how do you delete EGR, DEF and swirl motors? Do I want to do this?
Old Nov 25, 2020 | 07:24 AM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Oh yes you do bud.....
Old Nov 25, 2020 | 08:22 AM
boomie's Avatar
W166 ML350 Blutech
How do I go about that?
Old Nov 25, 2020 | 12:15 PM
Babukb2's Avatar
ML350
find a shop that does tunes and modifications for your model.
Old Nov 25, 2020 | 12:20 PM
boomie's Avatar
W166 ML350 Blutech
can anyone recommend a shop in Toronto?
this just disconnects the ad blue and stuff?
Old Nov 25, 2020 | 02:22 PM
Chamelleon's Avatar
Yes, Boomie, delete Ad-blue and EGR. and maybe DPF as well depending (I did not delete mine because it wasn't clogged up) and you'll solve your issues.
I had this done one year already and everything works just fine, plus I did stage 2 tune up, and the car is flying.
I could live with all these ecological stuff, and to be honest, I was trying to fix the Adblue heater, however, when my car when in limp mode (which is ok for me to drive in order to get the car to the shop, the car won't accelerate and drive fast but I don't need it at that point) while I was driving 120 on a highway, moreover, in 5 mins of driving in a limp mode all the systems went down, I saw all the lights on the dashboard, the steering wheel went stiff, and the car shuts off in the middle of a highway!!!, I managed somehow to pull over to the right, scanned the codes and Ive got a few codes related to some ecological stuff (sorry, forgot the numbers). After this incident, I decided to delete everything.
