keep or sell ML550?
Just looking for an opinion. I have a 2015 ML550 that I initially leased which I ended up buying out afterwards since I loved it so much (mainly because the newer models no longer had the v8....with the exception of the AMG63 of course). I purchased the extended warranty for peace of mind which has come in handy as various things were fixed under warranty (turbo coolant leak, transfer case leak, timing cover leak). My extended warranty is coming to an end this summer and I’m debating what I should do with the car now. I mainly drive it in the winter season only as I drive my Tacoma during the summer for its utility (mtn biking, camping, hauling around boat and kayak etc).....plus the ML is simply better in the winter.
How had the reliability and longevity of the ML550 been? Is it a money pit as they age? Just looking for some opinions....thanks!
Still a great platform, especially if you have one with On/Off Road or the Active Curve System. Very rare. Seems like the W167 isn’t as reliable yet.
Assuming you have Airmatic, I would budget $5k to replace the front and rear air suspension at around 150k miles. Quite a bit less if you’re on steel springs.
If you haven’t yet had the check valve done (ticking noise on a warm start), budget around $1.6k for that.
O2 sensors may get finicky at 150k, but those are $200 each - not terrible.
Brakes and rotors can be done for $800 with OEM parts.
Fluid filled motor mounts will definitely fail - likely $1-2k depending on the shop. Should also have the transmission mount and flex disk done around the same time - they keep the vibrations away.
Alternator between 150-175k will set you back around $2.5k from the dealer. If it’s just the voltage regulator then it is cheaper.
If your hub / bearings are worn (this is a nearly 6k lb vehicle after all), then that may need attention by 200k miles. Not sure on total cost since mine were under warranty.
The rear tailgate motor might die - that’s around $800 at the dealer.
12V battery is around $300-500 depending on make and shop. Those last around 5-7 years if they’re the OE Mercedes battery.
It all sounds like a lot of money dumped into the truck - but it’s worth it IMO. The comfort and noise insulation is still comparable to new SUVs today. In fact, my ML550 went down the highway better than my X5 does - I get a lot of head toss these days.
Good luck with it.
Good luck with it.
@SC22 Keep the ML -- do your research -- keep up with the maintenance and you'll be happy and proud for such a rare combo in the coming years.
Good luck with it.
Sometimes I wish you can just reach into the screen and slap the sh*t out of a poster.
All the prices you posted are literally pulled straight from your ***. 5k for airmatic replacement? $2500 for an alternator? $500 for a battery? Brakes and rotors for $800....LOL
I bet your service advisor gets a real kick and laugh when your foolish *** walks in.
This right here is a fine example of an individual with more money than brains. 😭🥱
