13 ml350 lost its trailer recognition module
Subscribe
Apr 28, 2021 | 01:27 PM
so last week we took a customers jet ski out for a test run before dinner no issues. got home and unhooked trailer but the car still thinks its connected. I'm getting blind spot system disabled and trailer light faults on the dash at startup. pluged in scanner and I have the following codes I RS-HRA - Outer Right Rear Intelligent Radar Sensor system(B29/5) 1 problems exist 1.552205 Signal ''Trailer'' from component ''Rear SAM'' is faulty. CURRENT and STORED SAM - Signal Acquisition And Actuation module(N10) 1 problems exist 1.U025287 Communication with the trailer connection unit has a malfunction. The message is missing. CURRENT and STORED Control Unit For Telematics Services 1 problems exist 1.B15CE00 Registration on the server for telematics services has failed. CURRENT and STORED IC - Instrument cluster(A1) 1 problems exist 1.U025287 Communication with the trailer connection unit has a malfunction. The message is missing. CURRENT and STORED
my scanner also cant find the trailer recognition module at all. it was there last month when I scanned the car playing with my new scanner but now its not. Any thoughts on where to start? location of said model, wiring pin, out fuse location? I haven't been able to find anything on google.
Reply 0
Jun 14, 2021 | 01:52 PM
Did you manage to sort it? I installed my towbar and all the wiring on my 2013 ML350 BT and may have some info on where they are. It was a Mercedes Genuine wiring harness + towbar + module as well.
Reply 0
Jan 18, 2023 | 05:39 PM
Help
Quote: so last week we took a customers jet ski out for a test run before dinner no issues. got home and unhooked trailer but the car still thinks its connected. I'm getting blind spot system disabled and trailer light faults on the dash at startup. pluged in scanner and I have the following codes I RS-HRA - Outer Right Rear Intelligent Radar Sensor system(B29/5) 1 problems exist 1.552205 Signal ''Trailer'' from component ''Rear SAM'' is faulty. CURRENT and STORED SAM - Signal Acquisition And Actuation module(N10) 1 problems exist 1.U025287 Communication with the trailer connection unit has a malfunction. The message is missing. CURRENT and STORED Control Unit For Telematics Services 1 problems exist 1.B15CE00 Registration on the server for telematics services has failed. CURRENT and STORED IC - Instrument cluster(A1) 1 problems exist 1.U025287 Communication with the trailer connection unit has a malfunction. The message is missing. CURRENT and STORED
Did you fixed it?
i am getting same issue as you describe, they told me i should replace the module?
dis u dix yours?
Reply 0
Jan 20, 2023 | 11:08 AM
I did. turns out the fuse for the trailer module was blown. it is located under the back seat. I have never owned a vehicle with so many fuse boxes.
Reply 0
Subscribe
Currently Active Users (1)
