Broken rear passenger door handle
Old Jul 1, 2021 | 11:02 PM
vnova94's Avatar
2012 ML-350
I have a 2012 ML350. I cannot open the rear passenger door from the outside. Inside handle works fine. Has anyone had this happen and found out how to fix? I’ve found threads about taking off the door panel… but will that even get me access to the handle parts? Any help would be appreciated.
Thanks,
Matt
Old Jul 2, 2021 | 01:29 AM
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
Thanks,
Matt
yes, take the door card off and check visually. How is an online forum supposed to help when you haven't inspected the visual mechanical components?
Old Jul 2, 2021 | 11:05 AM
mikapen's Avatar
Maybe someone on the forum knows the answer to the question. That's what forums are for. Reread the question.
Old Jul 2, 2021 | 11:09 AM
we47b1me's Avatar
ok
Old Jul 2, 2021 | 02:40 PM
chassis's Avatar
2017 GLE350 4MATIC
You need to diagnose it. Outside handle comes off via rubber plug in door shut face. Door panel (card) comes off to reveal door innards.
You need to get into it and see what is happening. Search feature on this site and YouTube will help.
Old May 22, 2022 | 06:06 PM
71406's Avatar
ML350 C63
Did you ever solve this problem with the door handle. The same thing happened to me. Thanks.
Old May 23, 2022 | 08:37 AM
vnova94's Avatar
2012 ML-350
No.. I never did get it fixed. Wound up trading the car in. Otherwise, I was planning on taking the door apart and seeing if something could’ve been JB Welded to avoid replacing the entire handle. Good luck. Hope you are able to fix yours.
Old May 24, 2022 | 12:30 PM
71406's Avatar
ML350 C63
Thanks for replying. This happened once before and the MB service manager fixed it while I was dropping off the car for service. Thought maybe someone learned the trick. Guess i'm going to the dealer!
