Adding a DSP to the H/K Sound System
I am wishing to add a digital signal processor to my ML63 W166 with the H/K sound system. (AudioControl DM-810 most likely).
1. Does anyone have access to a wiring diagram for this W166 HK sound system showing whether there are RCA outputs or just line level outputs.
2. Also, any knowledge of what color wires are for which speakers (especially given there are 14 of them!)
3. Where will I find the HK amplifier. HK sound brochure diagram (which i do have) shows it sticking out of the passenger front door (driver front door for USA people), but it is not clear whether that means it is in the door or under the front seat, or possibly somewhere else.
After reading the below, it would seem i need to put in the DSP after the amp utilizing the speaker outputs. Whilst this article is all about an S550, i get the impression the systems are very very similar. Same 14 speakers, just a higher powered amp in my case.
w221/W216 AUDIO UPGRADE GUIDE – UPGRADES FOR THE HARMAN/KARDON LOGIC 7 2007-2012 S & CL CLASS (wordpress.com)
Still keen to get as much information as possible, as I am still waiting on some parts before I start, so anything you can answer on is appreciated.
If anyone can think of anything I might also need to know, I am happy to hear.
Thanks in advance.
I haven't managed to find anything on here or you tube showing someone having done this, so if anyone has any links that would be appreciated.
If anyone has any of the info I am after i am keen to get hold of it.
There are many many wires coming out of that amplifier, so if anyone can help with identifying which wires are for which speakers that would be appreciated.
This indicates to me a 9 channel amp plus whatever is happening with the subwoofer which gets 2 pairs making, 10/11 channels overall.
1-4. The mid and tweeter in all four doors are on one channel each.
5-6 Each of the woofers in the 2 front doors are on one channel each
7-8 The rear surround speakers
9 The center channel
10-11 2 pairs of speaker connections are going to the subwoofer. Not sure why there are two pairs. Anyone provide any insight on this?
This diagram is a USA diagram and it would seem that in the USA the front right speakers are with the violet and violet/black on the right side of the car, whilst having already pulled off my left door panel and taken photos I know that for my Australian car the violet and violet/black are on the left side! Go figure. Same with the woofer colors. Probz means the rear doors colors are reverse as well.
For anyone that this info ever helps, the wiring diagram attached (at least the USA one) is pe82.62-p-2101-97aa . The data card code for the sound system is 810 (which was changed to 811 at some point in 2016).
Also, I have ordered an Connects2 CT10MC03 Connects2 - Vehicle Integration (Aerpro brand in Australia) which provides a way to make a bridging plug for connecting a DSP like I wish to do. (the product is for phones or something but it is a good way of getting the required connectors, male and female.
Anyway, i hope I help someone get going faster than I was able to if the ever want to do similar.
If anyone out there can confirm this channel arrangement and why there are 2 pairs of wires going to the subwoofer, your help would be appreciated.
This then seems to suggest that the amp is indeed an 11 channel amp, which given its size seems very surprising.
Just some more learning, learning, learning.
I ordered a Connects2 CT10MC03 Connects2 - Vehicle Integration (Aerpro brand in Australia) which provides a way to make a bridging plug for connecting a DSP like I wish to do. (the product is for phones or something but it is a good way of getting the required connectors, male and female).
I never ended up doing anything as i considered selling my ML63, although of course that didnt happen, and so i have done nothing! I may or may not get back to completing it.......................
