2015 ml350 leaking radiator advice appreciated
Old Oct 11, 2021 | 12:28 PM
mmhyson's Avatar
2015 ML350
hello.
i have a 2015 ml350 leaking coolant at the top left of the radiator. is this a known issue?
i have ordered a new radiator. is this a difficult job. i have not had to the joys of working on this car much. any tips or tricks you guys can recommend?
Old Oct 11, 2021 | 06:46 PM
Gibzki's Avatar
2012 ML350
I fixed mine by removing that cap/lock thing and filled that chamber with epoxy. No more leaks up to know.
Hope your leak is in the same spot (inside that chamber)
Old Oct 11, 2021 | 06:49 PM
mmhyson's Avatar
2015 ML350
when you say chamber what do you mean. it looks to me like it's leaking /pooling right where it mounts in the upper left corner what kind of epoxy did you use
Old Oct 11, 2021 | 06:58 PM
Gibzki's Avatar
2012 ML350
That small chamber where the upper mount is. When I remove that mount, it was pooling in that chamber. Clean that chamber real good and any steel epoxy should do it. I let it dry for 3 days before I used it just to be sure.
Old Oct 11, 2021 | 08:04 PM
mmhyson's Avatar
2015 ML350
Sweet. I bought a new radiator but will certainly give that a try. Thanks for sharing your experience.
Old Dec 25, 2022 | 05:27 PM
PUKBenz's Avatar
2011 E350, 2014 ML63 AMG
I have the exact same leak on my 2014 ML63 AMG. I’m going to do the epoxy thing in the next few days as well and I’ll report back my results.
Which exact epoxy did you use? Was it a high heat version?
Old Dec 27, 2022 | 12:04 AM
Gibzki's Avatar
2012 ML350
JB weld twin tube gray epoxy.
Old Dec 27, 2022 | 01:33 PM
PUKBenz's Avatar
Thanks. I'm going to use the grey high heat JB Weld tonight.
Old Mar 14, 2023 | 06:21 PM
Laryn's Avatar
ML400
Ml400 radiator slow leak
Hi, new to the forum, same issue with very slow leak from the driver side top radiator post cavity. Has the JBWeld fixed worked for anyone long term? Sure is a lot cheaper than $1k for a rad replacement - but not if it fails towing our trailer on a summer trip.. Thanks!
Old Mar 14, 2023 | 07:08 PM
Gibzki's Avatar
2012 ML350
2-3 years now and still no leak.
Old Mar 20, 2023 | 05:49 PM
Pmount1!'s Avatar
2014ML 350 Blutec
Had same leak on 2014 ML Bluetec, two radiator shops that advertise plastic weld repairs would not touch it, had it replaced, too many long trips to chance me trying to repair it. Glad your repair is holding up!
