Question about codes and not starting, shifting in D or N?
Old Dec 12, 2021 | 01:12 PM
mirinex's Avatar
2012 ML350 4Matic
Hi All - recently I got a 2012 ML350. I have some Weird electrical problems - both batteries have been replaced in the last week( main one with Die Hard Platinum H8 and small aux from Mercedes OEM) and it still doesn't start/crank at all. I am getting the Red "Service required do not shift Gears message", "Vehicle not in Park" and "Parking Brake". in addition to that "ABS/ESP not available" and "tele aid not available". The codes are as follows;
U010187- Comm with control init has a malfunction - message missing
U010387- Comm with electronic lever has a malfunction - message missing
P050008- Speed Sensor 1 has a malfunction- signal fault or missing message
P050000 - Speed Sensor 1 has a malfunction
C003108 - Please refer to service manual
C003408 - Please refer to service manual
C003708 - Please refer to service manual
C003A08 - Please refer to service manual
B226155 - not checked -Keyless Go Control Module not intiialized
B226196 - not checked - internal fault in keyless go.
Everything gets power and is working (lights, windows, radio, even door locks) but the front wipers! There is no Communication with ISM (A80) and ETC - electronic transmission control. All Fuses are Ok. Yellow parking light is on all times and it can not be switched off. Wondering if anyone has had a similar issue? Please let me know?
Old Dec 12, 2021 | 08:14 PM
chassis's Avatar
2017 GLE350 4MATIC
Any mods on this vehicle?
How long have you owned and and how many miles have you put on it?
What maintenance and repair work has been done on the vehicle in the past 12 months?
Old Dec 12, 2021 | 08:54 PM
mirinex's Avatar
2012 ML350 4Matic
It is all stock - no mods, it has 53k and I just got it.
Old Dec 12, 2021 | 10:03 PM
chassis's Avatar
2017 GLE350 4MATIC
Do you have XENTRY? This gives full visibility into the modules and codes.
Did you try clearing all codes?
Old Dec 12, 2021 | 10:47 PM
mirinex's Avatar
2012 ML350 4Matic
I did - they all come back right away. I am suspecting that something is making the ABS/ESP module, the ISM and the ETC not communicating. Not sure if they are controlled by one module like a CAN Gateway or the front SAM? Can anyone share a schematic pls?
Old Dec 14, 2021 | 09:03 PM
chassis's Avatar
2017 GLE350 4MATIC
It's not unheard of for a speed sensor to go bad. In which geography are you located?
Old Dec 14, 2021 | 09:59 PM
mirinex's Avatar
2012 ML350 4Matic
Can anyone point where the can bus on W166 is? I think that this might be my problem. 2 modules have no communication, all speed sensors have codes and ABS/ EPS ia unavailable. Can not think of anything else that it could be.
Old Dec 14, 2021 | 11:05 PM
mirinex's Avatar
2012 ML350 4Matic
I am in the North East but the car came from the South
Old Dec 20, 2021 | 11:35 AM
mirinex's Avatar
2012 ML350 4Matic
So After a lot of reading, digging, probing of wires, testing off keys/modules I am coming to the conclusion that someone did try to jump start it with the key in the ignition and fried something. So I have no communication with ISM,TCM and CGW. all other modules do communicate and have various comm messages. I have been looking for the CGW (central gateway) for a few days and can not seem to find it. Can anyone help in pointing out where that module is on a 2012 ML350 4Matic? On one place i saw that it was integrated in the EIS, can anyone confirm?
