How to get inside car if battery is dead?
Old Feb 2, 2022 | 09:08 AM
W203fanatic's Avatar
2012 ML350 Gas
Yes, chassis I searched only got 2 results searching “dead battery” in the W166 section.
So this hasn’t happened yet but I am just wondering how can you get inside the car if the main battery dies due to being left sitting too long?
Old Feb 2, 2022 | 09:35 AM
threeMBs's Avatar
Only MBs - the best or nothing
The same way as ANY Mercedes - use your little mechanical key (the one that locks the glove compartment) from key fob.
Old Feb 2, 2022 | 11:37 AM
2012 ML350 Gas
So there is a physical key in the key fob? Also a physical key hole in the door handle?
Old Feb 2, 2022 | 12:50 PM
chassis's Avatar
2017 GLE350 4MATIC
Yes. Search for it in your digital owner’s manual.
Pages 74-81
https://www.mbusa.com/content/dam/mb...V_Operator.pdf
Old Feb 2, 2022 | 01:37 PM
2012 ML350 Gas
Pages 74-81
Ahh perfect. Makes sense now.
I was worried for a bit because some cars like the E46 BMW there is no key to get inside the trunk which has the battery. Only way is to destroy a brake light and fish for the trunk release. I was worried Mercedes had no actual keyhole for the drivers door which gives access to the hood release. Smart design.
Thanks for the replies.
Old Feb 2, 2022 | 09:02 PM
Etienne Lau's Avatar
Ml350 bluetec
@W203fanatic Your vehicle will display other 12V symptoms long before you get to the stage where you cannot open your vehicle door.
Old Feb 7, 2022 | 11:03 AM
skippk's Avatar
What other symptoms?
Old Feb 7, 2022 | 12:38 PM
Ml350 bluetec
Car won't start is the first one. You'll have enough power to open doors, turn on radio, etc...It just won't start. Other symptoms include random flashing of lights in the dash etc....If you battery is sooooo dead you can't unlock the door, then you've let the battery drain down too much.
Old Feb 7, 2022 | 04:57 PM
YankTar's Avatar
2003 S5004matic (220)
Which can happen if it sits too long--like months or more during the lockdown.
Old Feb 7, 2022 | 05:20 PM
Ml350 bluetec
That's why I bought myself a solar panel, and connected the panel to the battery. And it keeps the battery topped up for months at a time......There just no excuse in my book to have a dead car battery.
Old Feb 7, 2022 | 05:49 PM
YankTar's Avatar
I gotta tell you, even with a Battery Tender followed by a Duracell smart battery charger, I had my S500 battery go TOTALLY flat repeatedly. So you can't be so sure there's "no excuse".
Old Feb 7, 2022 | 06:28 PM
Ml350 bluetec
Does you S500 use an AGM Battery? If yes, did Battery Tender and Duracell smart battery charger have settings for AGM battery? IF NOT then yah, any AGM battery will die. I ended up disconnecting my Solar Panel for this very reason, and resigned my self to driving the vehicle once every 2 weeks instead of letting it sit there for months at a time.
Old Feb 7, 2022 | 08:39 PM
YankTar's Avatar
No, it's not AGM. But I hope that driving it a minimum of every other day will keep it from going flat. I've been fighting a parasitic battery drain in our 2003 S500 4matic for several years now.
But, our 17 year old just got his license and I want him to drive this car rather than our Traverse, because it's old, it's book value is low, and it STILL drives like a dream!
Old Feb 7, 2022 | 09:20 PM
Ml350 bluetec
YankTar, I hear you, that's why my son is driving our 2001 Subaru Forester, about 5 miles each way to college and work to keep that battery from going flat. Bummer about your S500 parasitic loss. You try hooking up an Ammeter on the battery and pull fuses?
Old Feb 7, 2022 | 09:26 PM
YankTar's Avatar
Oh, hell yeah! Then had it to 2 specialist shops and NEITHER could find it! Talk to a stealership and you can't get a straight answer about what 2 hours of hunting for leaks with THEIR computer would cost!'
Old May 24, 2024 | 11:24 AM
tsair's Avatar
2022 SL63 AMG
Deleted..
