W166 engine stop once break
Old Feb 7, 2022 | 12:46 PM
Tey's Avatar
Tey
ML250 W166
My ML250 W166 engine will turn off sometime in low speed or break at gear position N or D but the engine lamp not show and after change gear position to P the engine can start again without any code alarm messages. The local workshop test with replace new sensor L5 but issues still remain. Please kindly advise
Old Feb 7, 2022 | 12:59 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the GLE.
Have you replaced the battery?
Old Feb 8, 2022 | 02:35 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W166 forum...
Old Feb 13, 2022 | 06:49 AM
Doubleredrolex's Avatar
2014 ML550 AMG package
I had a car that did that years ago. Low speed in the driveway or parking lot sometimes it would stall for no reason. It was an intermittently faulty crank position sensor. Might be something to check on yours.
Old Mar 5, 2022 | 07:37 PM
Tey's Avatar
Tey
ML250 W166
Yes, already replaced new but the problem still reman.
Old Mar 5, 2022 | 07:39 PM
Tey's Avatar
Tey
ML250 W166
Yes, already replaced new one but problem still remain
Old Mar 5, 2022 | 07:43 PM
Tey's Avatar
Tey
ML250 W166
Thank you very much I’ll check on that
Old Mar 13, 2022 | 03:57 AM
Tey's Avatar
Tey
ML250 W166
Replace both crankshaft and camshaft sensor but the the engine still stop once slow speed without any engine lamp ala
Old Mar 13, 2022 | 09:25 AM
chassis's Avatar
2017 GLE350 4MATIC
What codes have you read?
What led you to replace the sensors?
What modifications are on this vehicle?
Have you replaced the auxiliary battery in the rear cargo area?
Old Mar 13, 2022 | 11:05 AM
Tey's Avatar
Tey
ML250 W166
The engine lamp not show and not have any alarm just engine stop and can start again.
Already replaced auxiliary battery, crankshaft sensor and camshaft sensor.
But the problem of engine stop once break at the slow RPM still remains.
Old Mar 13, 2022 | 11:44 AM
chassis's Avatar
2017 GLE350 4MATIC
Read codes, there may be stored codes that don't turn the CEL on.
What modifications are on this vehicle? Nice color.
