ML350 vibration in the rain, not in the dry
Old Oct 27, 2022 | 10:34 AM
M~Factor's Avatar
2017 AMG GT, 2015 ML350, 2013 C300
I've had this issue for years now and its time to ask for help. I'm getting moderate to HEAVY steering wheel vibrations in the following conditions ONLY:
  • in the rain (and i've turned on the wipers)
  • when I have my aftermarket ENKEI wheels (no TPMS)
the vibration does not happen in ANY of the following situations:
  • not raining
  • drizzling but I haven't turned on my wipers
  • when I have my OEM wheels/tires on
My first thought, as everyone would suggest, is to balance all 4 wheels/tires. I've done that. 4 times to 4 different shops. Besides, if its balancing is the problem why doesn't it vibrate when its not raining? vibration degree varies depending how long I have been driving with the wipers on. sometimes it vibrates so much I can only drive it under 45 mph.
Old Oct 27, 2022 | 10:39 AM
chassis's Avatar
2017 GLE350 4MATIC
  • not raining
What other mods are on the vehicle?
When were the brakes last replaced and who replaced them?
Old Oct 27, 2022 | 10:57 AM
M~Factor's Avatar
lowered HRS springs
front splitter
I've replaced the brakes and rotors myself 2 years ago. the truck only has 59K miles.
I don't think none of these are an issue because once I switch back to OEM wheels and tires, the problem doesn't exist.
Old Oct 27, 2022 | 10:59 AM
Gray_Panther's Avatar
ML400 - 128i - Atlas VR6
Condition of the tires on the Enkei’s. This sounds like it is tire related since the OEM wheels are fine and that the Enkei’s have been rebalanced a bunch of times.
Also, what bolts are being used on the wheels and do the Enkeis have conical or spherical shaped bolts. Could it be that the Enkeis have conical recesses but the bolts are spherical and may not be tightening down the wheels all the way to the hub?
Do the Enkei wheels have hubcentric adapters? if the hubcentric adapters are not there or incorrect size it may not mount flush to the hub which can cause above mentioned issue as well I believe.
Edit: bring these questions to mechanics and hear what they have to say.
Old Oct 27, 2022 | 11:13 AM
M~Factor's Avatar
I do have the correct lugs for aftermarket wheels. no spacers are being used. torqued them a few times over the 5 years i've had this issue.
Plus why would it only vibrate in the rain? And after I've used the wipers for a bit. These are all my personal observations over the years. When it rains, without fail it happens. sometimes its bearable. sometimes I have to drive under 40 mph just to get home.
Old Oct 27, 2022 | 12:05 PM
What is the condition of the actual tires then?
is there a bubble anywhere? Is the tread low?
When the tread is low then the vibration occurs in the rain.
Old Oct 27, 2022 | 12:20 PM
M~Factor's Avatar
Make sense. The thread is still pretty good, plenty of thread left. maybe under 10k mileage. No visible irregularity.
Old Oct 27, 2022 | 12:43 PM
chassis's Avatar
2017 GLE350 4MATIC
What is your guess on the cause?
Old Oct 27, 2022 | 12:54 PM
M~Factor's Avatar
Well, I remember reading something about Mercedes has a sensor that detects rain and when it does it tightens up the braking system a bit more. So I'm thinking when it rains, detected by running the wipers a few times, it tightens up the braking system but its not detecting the TPMS which affects braking? Crazy, I know, but its not too far fetch.
For me, the only difference between my aftermarket wheels and OEM wheels are the TPMS sensors. Tire thread are pretty much the same.
Old Oct 27, 2022 | 02:07 PM
I have GLE wheels that I use in the winter but the PO snagged the TPMS for himself so I run them without TPMS and I never experienced any vibration, whether raining or not.
Old Oct 29, 2022 | 04:36 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Have you tried disabling ESP in the cluster?
Except for the TPMS missing on the non-OEM wheels, you seem to have checked all the common concerns: centered hub, correct lugs, proper torque, and "not bent/out of shape" wheels, correct? On dry pavement, the tire walls will take any disturbance because of the higher friction while on wet it is a toss. If the tire slips you will feel it stronger, not that it was not there before.
Old Oct 29, 2022 | 05:11 PM
E55Greasemonkey's Avatar
This place is a joke.
Are the wheels hubcentric or not? I'm guessing not... and the dry braking feature is agravating the condition.
Old Oct 29, 2022 | 05:18 PM
M~Factor's Avatar
That is correct.
Once it rains again and I'm on the highway, I will deactivate the ESP. Hope this will help. Thank you.
The wheels are hub centric.
Old Oct 29, 2022 | 06:16 PM
chassis's Avatar
2017 GLE350 4MATIC
@m-factor have you ordered TPMS sensors?
Old Oct 29, 2022 | 06:45 PM
M~Factor's Avatar
I did. An aftermarket one. They were supposed to be pre-programmed when I received them but they didn't work.
I tried getting them program by a shop to no avail. Honestly, at this point, I am done with these wheels. Once the tires on these go, I will get rid of them. So I don't want to spend more $$$ on these wheels.
