14 ML350 a/c quit
Old Jun 30, 2023 | 01:54 PM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
14 ML350 a/c quit
Anyone ever tried one of those recharge kits from a parts store? Thanks.
Old Jun 30, 2023 | 03:24 PM
mike919's Avatar
86 190E 2.3, 2014 ML350 Bluetec
A/C systems don't just "quit"
have the system diagnosed for leaks and refill with the correct gas, off-the-shelf kits are a substitute freon gas for consumers.
Old Jun 30, 2023 | 10:15 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Under no circumstances do recharge modern MB AC systems w/o evacuating it, checking for leaks and weighting the correct amount of refrigerant for your vehicle.
Adding refrigerant by monitoring pressure with variable displacement compressor is bound to damage the compressor. The electronic control valve may adjust your pressures, and mistakenly overfill your system
Old Jul 1, 2023 | 02:16 PM
pjw1967's Avatar
Thanks. I was dreading the ride from Galveston to Montgomery this morning so I was looking for a quick temporary fix. Got in the car at 0715 and the a/c was working a little bit. So the ride to the dealer was ok. They'll look at it Monday.
Old Jul 1, 2023 | 02:53 PM
JCM_MB's Avatar
Fingers crossed it is only refrigerant. If it is the ECV intermittently working, it will be a new compressor since MB doesn't sell the $50 repair part ->> $1000+ at the dealer.
Or an intermittent sensor should be luck as well
Old Jul 4, 2023 | 06:32 PM
pjw1967's Avatar
Update
Dealer called to say it was 2 lbs low. They topped it off and put in some dye. When it starts to warm up again I'm to bring it back so the can look for leaks.
Old Jul 4, 2023 | 06:52 PM
JCM_MB's Avatar
Fingers crossed is still the valves
Depending on the AC feature code , the amount of refrigerant can be different. Mine takes 900+ grams, i.e. 2 lbs.
