Headlamp types?
Old Oct 28, 2023 | 07:26 AM
Don_CA's Avatar
ML 350 Bluetec
Headlamp types?
How do I know if my 214 ML350 bluetex has halogen, xenon, or LED headlights?
Old Oct 28, 2023 | 10:15 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Rrun your VIN through www.lastvin.com
Old Oct 28, 2023 | 10:16 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
If you look at the top of your headlights with the hood opened, it will tell you what you have. If the light is really crummy with a yellowish tint, you have halogen. Unless someone put in aftermarket bulbs, you don't have LED.
Old Oct 29, 2023 | 10:08 AM
Don_CA's Avatar
ML 350 Bluetec
I am pretty sure I have Xenon HID. Very white until one started going pink and last night went out. I'll use the VIN thing to check. Here we go: BI-XENON HEADLICHT W.ACTVIE CURVELIGHT RIGHT-DRIVE
Old Oct 29, 2023 | 10:28 AM
Don_CA's Avatar
ML 350 Bluetec
Are they correct? They seem to be:
Amazon Amazon
and on sale at the moment
Old Oct 29, 2023 | 11:02 AM
2013 ML350 Bluetec
I believe the D1S is the correct replacement, but you might consider the LED equivalent. I've had these in since August with no issues; another member recommended them to me.
Amazon Amazon
I've found the low beams to be extraordinary, the high beams to be xenon equivalent. The high/low is of course the same bulb with a shutter to modulate the output.
Old Oct 29, 2023 | 11:17 AM
BlownV8's Avatar
D1S D1R LED Headlight Bulbs Replace HID Lamp Conversion Kit 24000LM 6000K White | eBay
Much cheaper on Ebay.
Old Oct 31, 2023 | 08:17 AM
Don_CA's Avatar
ML 350 Bluetec
Different brand (may be the same hardware), but also I am in Canada and those do not ship here. Also, fleaBay, ew.
Old Nov 2, 2023 | 03:05 PM
Don_CA's Avatar
ML 350 Bluetec
I installed them this afternoon. When I had one done and one Xenon, you could see the difference in brightness, but I know the old lamps dim over time. I look forward to trying them at night.
