2015 ML 350 Relay "N" Engine Bay Fuse Box
Old Mar 5, 2025 | 11:14 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Relay N is for circuit 87M: starting circuit. Without fuse, the relay will not work; therefore, not starting capabilities.
CaliBenzDriver suggestion is to reboot the car: disconnect the main battery and the auxiliary in the left sidepod in the rear. Wait , and reconnect. You can remove the negative on each and wait before reconnecting.
The same idea of removing the battery on a laptop: main and coin , press power to discharge capacitors, and reconnect. Voila laptop now works, or works better.
Old Mar 5, 2025 | 11:22 PM
2015mbml350's Avatar
Sorry, I am a bit lost - are you suggesting rebooting the car to fix the issue related to the Electronic Ignition Lock Control Unit, or the issue related to car not starting?
Old Mar 5, 2025 | 11:26 PM
JCM_MB's Avatar
Rebooting to have a clean environment to continue testing.
Cali's suggestions is the network is already compromised. Once reset we can see the natural state of it. I reboot my cars once or twice a year when I charge/refresh the batteries with a CTEK charger
Old Mar 5, 2025 | 11:28 PM
Gotcha, will do!
In the mean time - do you know what "Electronic Ignition Lock Control Unit" is referring to?
Old Mar 5, 2025 | 11:41 PM
JCM_MB's Avatar
Gotcha, will do!
Past models had the electronic steering lock , ESL. It was a nightmare with an electric motor wearing out, seizing or dying and the car would not start at all. Not even crank.
Newer models seem to call it Electronica ignition control lock. There no steering locking, and why asked earlier. Still there is a security/theft prevention system to protect your investment, and apparently drained too. I assume that system is hosted on the ECU or the ignition switch.
I do not have the circuit diagram to tell. Likely required to understand the remaining pieces
Old Mar 6, 2025 | 01:08 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
You are probably right - the wheel is not locked when key off, I can still turn it.
But this looks like it is related to ignition switch.. when I had the fuse unplugged, neither the push button nor the key would start the car...
JC knows what makes these cars tick and why they stop ticking.
Do not troubleshoot pulling relays... it will only waste your time and money....
Don't pull any parts from a powered chassis else reboot afterwards or best power down first.
Nothing is plug and play in these networked car computers.
