Changing transmission oil, blue or green?
MB spec 236.14 without code A89 https://operatingfluids.mercedes-benz.com/sheet/236.14
MB spec 236.15 with code A89. https://operatingfluids.mercedes-benz.com/sheet/236.15
Your fluid is:
Ignore fluid color. Spec compliance is the determinant.
I even drilled off some metal where the rubber grommet is at to get better access similar to the vid by Sr. Leigh on youtube for his E class.
Re-reading your post I see you are referring to the torque convertor plug which I have yet to tackle. I may elect to simply leave the fluid in the TC and step up the drain interval to deal with whatever tired fluid dilution may result from ignoring the TC grief.
