Ml 550 Motor blown
I have a 2014 W166 ML 550 and am wondering if it’s possible to do a motor swap with any of the following M278 motors as it’s impossible to find an ML class motor. As it all seems good to go my concern is buying it and it not fitting
CLS 550
GL 550
S 550
And more…
any help is appreciated thank you
Worth listening to the effort to find a decent M278, and what you may be against.
Hope you are aware the M278 engine cylinder material changed during production, @March 2015 from aluminum coated to iron-cast coated cylinders. You may want to look for an engine after that date. However, they are also apparently prone to cylinder scoring. The issue may be the coating, and not the core cylinder material though.
Here for the M278 thread in the W212 forum ( https://mbworld.org/forums/e-class-w...ml#post8905320)
that’s great to know and thanks for the video link, I had no clue.
1 - Ask if the VIN of the donor is available
2 - Input VIN into the EPC or one of the MB online parts store
3 - You may see several options for the "same part" based on the VIN. With a list of compatible Model/Class
4 - The last stick is: even if the part is identical, the donor car features are identical, it may still be considered theft relevant --> Coding is required.
For example, the M276 NA is different in all classes. The ML350 requires more oil than the E350 which I assume is a different oil pan.
Summary: they may look the same to the naked eye, but there can be subtleties; therefore, research is required.
