ML350 BT W166 Odd ABS issue
Recently I changed a water pump, and sealed the vacuum pump while I was there, I had a friend helping who changed the PCV that goes to the Turbo.
All went ok except as soon as I drove it feels like the right front wheel goes into ABS at slow braking ????
Could it be just back luck that the speed sensor failed at that same time?????
or
I am wondering if there is any ABS or Speed sensor wiring/connectors around the back left hand side of the motor, he did remove and disconnect some of those brackets to get at the PCV.
My scanner shows a store transmission fault where all speed sensors have failed ??? Unfortunately will not show real time data for the speed sensors as it dosnt recognise the module ??? (Autel Scanner)
Any Ideas
Reagrds
Terry
Asn8s your Autel does not shows ESP whell sensor data ???
