Upgrading screen / Apple CarPlay options ..
There are two options,
1) installing unit that allows Apple CarPlay with the factory screen
2) installing aftermarket screen
Considering the price points, I’m leaning towards an aftermarket screen. However, I’m signing that extensively the same screen price points very dramatically, depending on vendor .
Has anyone installed this unit? If so, any issues and what vendor did you use?
My reasoning to go with the original screen option was to keep the suv original if I ever wanted to sell it. If you plan on running this suv to the ground, I'd go with the aftermarket screen (the first image you showed). I went with the company RoadTop on Aliexpress and the unit is great. The customer service was also great. Don't pay more from other sellers when the unit is exactly the same! They're all made in the same factories in China.
Original screen option is way less expensive and you keep the original look.
Aftermarket screen option is much more expensive and you don't keep the original look. However, you get a bigger screen with touch screen.
Original screen option = Link
Aftermarket screen option = Link
Good luck!
I like that it connects automatically and have only had 1 "issue" where it didn't connect. I simply "forgot this device" from the phone and paired back and has never happened since. Love the touchscreen option and it does allow you to go back to the original NTG interface (Not touchscreen) if needed. Back up camera is original and works fine. I do need to figure out how to keep the camera on the screen when going forward after backing up. With the 360 camera original equipped, the front camera would be on the screen until x mph is exceeded and then turns off after reversing. With the aftermarket screen as soon as you come out of reverse the camera turns off on the screen. Only works when I'm on the original NTG screen.
Purchased mine fro Aliexpress, better priced than Bay or Amazon. No issues and good communication with seller.
Depending on what your looking for, Roadtop can be an option but if your looking for touchscreen capabilities the android device initially mentioned by the OP is the way to go.
