Hard riding Airmatic
Old Jan 12, 2025 | 01:21 PM
HamMan's Avatar
2015 E400 Cab - 2013 GL350 - 2013 ML350 - 2006 E350 - Old Jeep
Just bought a 2013 Gas ML350 (USA) 19" wheels, Airmatic and 96k miles.
The rear end seems to have very little travel.
As if it is bottoming out on speed bumps.
I have been to two different independent shops with no signs of leaking or seepage so conclusion.
The car is always level, the compressor is not constantly running.
It will raise and lower on command.
Comfort or sport make no difference.
No codes.
Is there some kind of "reset" for the Airmatic to "cure" this harsh condition?
I did have a PPI with no issues (must not of driven it).
Please help, I may end up selling this one if not resolved.
Old Jan 12, 2025 | 02:05 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Can you bounce the back bumper and get good travel or do you feel like you're hitting stops? Any difference bouncing the car when it is running or turned off?
I wonder if the airmatic shocks (not the airbags) have an electrical issue. Does unplugging the electrics on the shocks make a difference?
Curious how much you paid for the car... I have the same machine in diesel form.
Edited to add: What does a scan with a good scan tool show regarding the suspension system?
Old Jan 12, 2025 | 06:18 PM
HamMan's Avatar
Scan tool at shop showed no error codes stored or current.
Shop was fine with replacing rear shocks for $2,300 but thought there would be no change.
In Arizona MLs are a dime a dozen, take your pick from $10-$15,000. Ten for mine
Bouncing from the bumper in very stiff with car on or off
btw tires are 7 years old and at correct pressure, I have driven on hard tires and these are not hard.
Car has been garage kept and dealer maintained until 20.000 miles ago.
Many repairs on Car Fax none with suspension issues.
I do not have a lift, maybe disconnect the battery for 5 min would "reset" things?
Would this be done under the hood or at the battery?
Old Jan 13, 2025 | 05:13 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Does your car have ADS?
Old Jan 13, 2025 | 12:58 PM
HamMan's Avatar
Yes
Old Jan 14, 2025 | 01:03 AM
Quattrodude's Avatar
2011 E550 - 4Matic, 2008 ML550
Did you check to see if you have aftermarket shocks?
Many of them bypass the ADS function and just have a plug that fools the system to thinking its does.
These type (of generally very cheap) shocks might be your cause.
the rear shocks in our W166's for Airmatic are 3 easy nuts to remove and replace, it will take you longer to remove the rear trunk trim to get to the top two bolts.
Might consider - Arnotts or even OEM Bilstiens if you want to go that route, be under 1K for both shocks and DIY.
cheers
Old Jan 14, 2025 | 10:42 AM
2013 ML350 Bluetec
I got some Bilstein airmatic sticks and airbags for the rear axle of my ML for about $1800 from Amazon. As stated, the hardest part of replacing the shocks was removing all the interior cargo area trim to access the shock top bolts. It wasn't hard, just a lot of it. FCP Euro has an excellent How To video on removing the panels.
