Auxiliar battery !
Old Mar 13, 2025 | 05:04 AM
George.'s Avatar
ML 350 BlueTEC 4-matic
Auxiliar battery !
Good morning dear Mercedes fans,
I am the owner of a lovely ML w166 350diesel AdBlue - 2012, 2 years ago ,being the car of my dreams for 10 years now....
I had a problem with the gearbox module (ISM) in December 2024 (while driving for Christmas to my hometown) and was replaced at Mercedes official garage(2 years warranty), then I drove it 4000 km in 2 parts because this is a garage car and I use it for long distances only,
5 days ago I wanted to drive it after 2 weeks of sitting in garage and it was Not possible to place it in D(drive), it was stuck in Parking mode, even though the engine start normal...
I don't have any error message on dashboard.....
I have a question please,
is it possible that the auxiliar batter could create this problem ?
I am thinking also to bring a specialist to the car and maybe he can see the problem with a tester and hopefully have a diagnose...
But till then, did you guys encounter such a thing and what was the solution in your case ?
Thank you and have a great day !
Old Mar 13, 2025 | 08:04 AM
W205C43PFL's Avatar
Yes it is possible but not a definite cause. Only way to know is to replace it and see if it solves the issue, otherwise you are just doing trial and erroring.
Old Mar 13, 2025 | 08:12 AM
W205C43PFL's Avatar
I recommend getting a scanner that is capable of reading MB codes like a Launch CReader benz or going to autozone to scan for codes.
Old Mar 15, 2025 | 05:20 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Mr. G.:
Realize that replacing the costly ISM did NOT really fix your issue.
At this time it's a really good guess to suspect the AUX Batt circuit (Batt + fuse).
Use any cheap voltmeter to measure your AUX voltage near 12.5Volts
Then use a CTEK or equivalent float charger to top off both batteries. (Alternator IS NOT a good battery charger).
Do purchase on (Internet: Amazon) a $150 Launch cReader MB Elite scanner to diagnose your chassis - It'll pay for itself the first time you use it (Skip the toy Bluetooth gizmos testers). Specifically buy a "Launch" everyone around here likes to use.
The bottom line here is you have a voltage disruption preventing normal CAN Bus functions.
Fix may be as simple as...:
  1. Battery charge
  2. Reboot chassis
  3. Scan
  4. Clear faults
Cost: 0.
Never let your MERCEDES DRAIN YOUR BATTERIES flat without a "float charger".
Old Mar 15, 2025 | 05:53 PM
W205C43PFL's Avatar
Mr. G.:
  1. Battery charge
  2. Reboot chassis
  3. Scan
  4. Clear faults
Cost: 0.
Don't forget to link your reboot thread so it is extra clear : ) https://mbworld.org/forums/e-class-w...eboot-how.html
Old Mar 15, 2025 | 06:18 PM
SETUP FOR FUNKY THRESHOLDS
You're right !!
Later today I will write a quick explanation about...
how low/variable/unstable voltages are used to disrupts CAN modules (active vs. sleep)
and why chassis Reboot fixes resets this chaos.
Old Mar 15, 2025 | 08:00 PM
W205C43PFL's Avatar
You're right !!
Looking forward to that : )
Old Mar 16, 2025 | 01:23 AM
voltage sensitive princess
I did write how low voltage may occasionally rope in customers with unsettled ownership experience.
> Translation:
-- We can realize that Mercedes designed awesome chassis that run right when daily driven and become service oriented when driven seldom.
-- The simple shortcut is to maintain battery voltage with an automated charger - Who needs endless aggravations ???
Old Mar 16, 2025 | 07:03 AM
W205C43PFL's Avatar
> Translation:
