ML350 BLUETEC any experience resetting values of Hot Film Management Engine drift
Old Mar 16, 2025 | 09:50 AM
FunEddy's Avatar
Hi, My 2014 ML350 BLUETEC has some stored DTC's 100C00 and 100E00 relating to the hot film mass airflow sensors. Iintend to replace the MAF unit. After the replacing I am unsure if I will need to "reset the values of the Hot Film Management Engine drift compensation" ?.
Any experience or advice or information would be greatly appreciated.
Old Mar 16, 2025 | 11:06 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
S T O R E D !!
How about not replacing good parts...
PLAN B:
--1-- Why not simply reset all these faults and float your main battery to full.
--2-- Then scan to see what comes back.
I know that transient faults come right back as STORED without ever being CURRENT.
Lets see...
Old Mar 16, 2025 | 11:22 AM
FunEddy's Avatar
Before I buy parts
Thanks for your suggestions STORED. Can I confirm
- dont start replacing parts
- clear all DTC's (stored and current) and see what returns ?
- you mentioned something about the battery ?
Cheers
Old Mar 16, 2025 | 01:27 PM
Cheers
Yes, you got it!
About battery voltage:
use a good automatic charger to recondition it. It may be what is causing all these false faults.
