Engine vibrating on cold start but clears after it warms up.
Am a first time Benz owner, bought 2015 ML 350 4matic at 115k miles.
Noticed the engine has this rough idling (also vibrates) during cold start. But after it warms up and switched off for about 20-30 minutes, the rough idling/engine vibration clears when you start the engine again.
I earlier suspected a faulty ignition coil, so we changed for bank 1 & bank 6, but the situation still persists.
I will appreciate some advice from your collective wealth of experience.
"bank 6" is Bank 2 cyl. 6, right?
Can you use a scanner to scan ECU... & clear faults?
This will get it to relearn mixtures
How old are the spark plugs since replaced?
- cant say, only got the vehicle for about 1 month.
- We actually suspected a faulty ignition coil which was replaced but the issue persisted
- yes bank 1 and bank 6
- Ok, i own a Bluedriver scanner, the last scan i did pointed to the injector but a quick check on google suggested poor quality fuel.
- Will re-scan and clear faults then observe behaviour
Thank you so much, appreciate your support
Result in detuned engine power.
Part of that is carboned-up Lambda sensors from engine burning thin oil meaning don't just replace sensors, upgrade oiling as well.
Thank you so much
Am gathering good experience already.
Appreciate
Lots of experience here, to use
The issue was partly pinned to faulty ignition coil on bank 6.
After replacement of faulty ignition coil on bank 6, i took the vehicle out for a long drive, with several shift down hard driving, the injector issue eventually cleared.
Guess it was some debris clogging the injector, being forced out under pressure during the long drive
I immensely appreciate everyone's contribution on this.
