2012 ML350 BlueTec issues
Old Apr 29, 2025 | 11:37 PM
206113@'s Avatar
W166
Hi guys, I just got a 2012 ML350 BlueTec — two quick questions:
  1. Should it beep when the indicator is on?
  2. Will the "engine" light come on the dash if the thermostat is broken?
Anyone know? Thanks!
Old Apr 30, 2025 | 08:07 AM
bobofthenorth's Avatar
2013 ML350 Bluetec
Should what beep when what indicator is on?
Old Apr 30, 2025 | 09:56 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
The turn signal indicator barely goes "click" and that's because it has a noisemaker. It's electronic.
Yes. If the thermostat doesn't get the engine to the temperature the ECU expects in the time the ECU expects it to get there, it'll throw a code.
Old Apr 30, 2025 | 09:59 PM
206113@'s Avatar
W166
thanks, mate.
I bought this vehicle two years ago, and I'm sure the thermostat was broken because the coolant temperature couldn't reach the normal level. However, I didn’t see any warning or error message on the dashboard.
Another thing — does this ML need AdBlue refills? I see there’s an AdBlue tank, but I haven’t received any refill warnings, even after driving over 20,000 km.
Old Apr 30, 2025 | 11:11 PM
2013 ML350 Bluetec
thanks, mate.
In factory trim it needs AdBlue. At 20,000 km I suspect your car has been deleted. Look for loose connectors which were previously attached to parts of the BlueTec system. There should be a couple under the chassis where they would have attached to the DPF. There will also be a great big one in the right rear quarter panel next to your auxiliary battery but its a little tricky to see. You may be able to see it through the inspection hatch over the battery using a mirror. Its big - like 1.5 inches by 4 inches.
Old Apr 30, 2025 | 11:55 PM
206113@'s Avatar
W166
thanks, mate, is there any negative impacts if it's removed for this vehicle?
Old May 1, 2025 | 06:43 AM
2013 ML350 Bluetec
Depending on your jurisdiction there may be legal implications. Personally I think there is nothing but good mechanically. When I bought mine it was pretty much the first thing I did but I live in a jurisdiction without annual re-inspections. I think I could pass one but I don't have to so it doesn't matter.
Old May 2, 2025 | 12:02 AM
206113@'s Avatar
W166
thanks, the only thing I'm confused is why there is no error code on the dash though the thermostat was broken
