Crank Won't Start
Old May 16, 2025 | 08:33 PM
zxz235650's Avatar
2014 ML350 4Matics
Crank Won't Start
Hi there! When I try to start my car today it just crank but won't turn over. Read code P2088 2092 2094 2098 camshaft acurator low circuit codes, sometimes have 0498 EVAP Vent valve control circuit low 0031 HO2S heater control circuit low bank 1 sensor 1. Had other low circuit code as well as ECM communication codes. Checked fuses in the engine bay, battery seems fine, tried jump start, oil is ok. All visible wires seem fine, but I do have pending water in the truck recall that I didn't go, could it be fuel pump control module or other causes? Seems to be some kinda wiring issues.
What is the cause? Low battery? Car crank strong though.
Old May 21, 2025 | 08:57 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
CRANK NO START
Originally Posted by zxz235650
Hi there! When I try to start my car today it just crank but won't turn over. Read code P2088 2092 2094 2098 P0031 P0498 P0507.
What is the cause?
Low battery?
you should really translate these faults your computer picked up...
this obvious step will help you understand without blaming the battery.
Seems you're dealing with compromised engine sensors. The fault codes will show to what extent.
Old May 21, 2025 | 09:01 PM
zxz235650's Avatar
2014 ML350 4Matics
you should really translate these faults you picked up...
Sorry! Updated! I dropped the car at a mechanic. Will report what they think.
thanks
Old May 21, 2025 | 09:04 PM
bobofthenorth's Avatar
2013 ML350 Bluetec
You've got a bit of a dog's breakfast there but the ones that are stopping it from starting are likely the cam actuator codes. Both banks - sudden onset - I'd figure out what fuse is involved and start there.
