What are hall sensors?
They're a part of an ABS brake system; using hall sensors the car knows how fast each wheel is turning. That info can also be sent to a speedometer.
PS: Your google fu needs work...
https://www.google.com/search?q=what...hrome&ie=UTF-8
I'm not 100% sure of the answer and maybe someone with more direct knowledge than I have will respond, but I would imagine a hall sensor is a large part of the camshaft sensor. Magnets on the camshaft end (a tone ring), a hall sensor to generate a signal from the tone ring.
https://www.google.com/search?q=do+c...hrome&ie=UTF-8
The cam sensors pick up a signal from the reluctor wheel that is pressed onto the front of the Cam shaft. The reluctor wheel has gaps in it that the sensor pics up on. The sensor pics up on the metal section of the wheel.
