ML350 W166 Blower Motor Wiring Repair
Old Nov 2, 2025 | 12:16 AM
pahanorlando's Avatar
In case anyone will encounter this, here is my repair of somewhat common wiring issue with a blower motor on W166 ML350
Old Nov 2, 2025 | 06:20 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
HIGH LOAD SETUP
thank you for showing us this burned connector repair.
Same exact connector issue is available with the DC in-tank fuel pump (passenger side rear seat).
> ROOT CAUSE ...
Electrical current is exceeded by high motor load condition.
-- Blower motor use tight dry sleeve bearings to acomplish high-load (lubricate dry shaft!)
-- Fuel pump pumping through 120kMi. dirty filter over heats on 2x current.
The actual fix is to reduce the load to normal levels.
> Funny Thing...
We know how excellent SAM's are at monitoring precisely load current... too high, too low except.Unfortunately blower & pumps are left out unmonitored. Go figure...
These circuits are only fused against short-circuits so vehicle tolerate abnormally high currents by developing poor connection.
Samouraï dole keeping watch (Tokyo)
Old Nov 2, 2025 | 08:53 PM
Interesting, thanks for the info. To make sure I understood it correctly, I need to lubricate heater motor shaft? Is there video on it?
Old Nov 3, 2025 | 12:27 AM
Some classic cabin blower are squicky dry early on... (East Europe Bosch mfg).
Add 2 drops of oil for top + bottom sleeve bearings.
Cabin filter needs not to be totally plugged up by dust that prevent air flow.
Beware of the fragile wiring to the temp sensor when pulling the upper plastic cover of footwell area, 3x screws.
Old Feb 26, 2026 | 12:55 PM
mfobare's Avatar
ML350
Accessing the Blower Motor Fuse block??? 2014 ML350 W166
2014 ML350 W166 - I've gone into the battery compartment where the 40A blower motor fuse is located. However the fuse block is "hidden" next to the battery in a cubby hole there. After removing the battery there does not appear to be any way to access the fuses. Can someone give me some advice on how to access the blower motor fuse without removing the entire floor board and passenger seat?
Is there a way to check it while still in place?
Thanks!
Old Mar 9, 2026 | 08:59 PM
mfobare's Avatar
ML350
Does anyone have the part number for this connector and the pins for the positive supply?
