How difficult is tranny flush??
Draining the fluid is done at the same hole, but the filler standpipe must be dislodged by prying it out of place with a screwdriver or some such. That tower (standpipe, whatever) remains fallen in the pan until the pan is removed from the vehicle.
It'll all be much more clear when you see what is in the service kit and watch a video or two. Making sure the fluid temperature is correct is the only really important part, the rest is just messy.
The transmission temperature can be read with a scan tool.
At the very least, OE parts carry a basic quality certification to meet preset standards.
Brakes? There are aftermarket options that are both far cheaper and far superior.
"Automatic Transmission 725.0 AP27.00-P-2702B $1129.08"
Why would a drain and fill cost more than a flush? She asked but the SA seems to be a little "English-challenged"; we're inclined to go with the flush; thoughts??
FWIW, this non-dealer German car specialist, Star Tech in Denver, wants $371 for spark plug replacement (Dealer $607.78) and $417.50 for front brake pads (Dealer $637.73). For the trans. service the dealer quoted "TFE3 Transmission fluid/filter service @ $1171.67"!!
The drain and fill is labor intensive AND you get a fresh filter.
IIRC the drain and fill is recommended service. A flush is not so much due to the issue of dislodging crud with the pressures involved, and that leads to shifting issues thanks to that crud getting into places it isn't welcome (solenoids, valve bodies, oil passages, etc).
Drain and Fill in MB is a lot more work than power flushing the lines and refill. Wonder how they plan to refill it.
SUMMARY: if the technician is not familiar with these transmissions, RUN. Likely they will use the wrong fluid, fill to the wrong level
Best,
Steve
