M276 Engine Oil leak?
The Bk1 upper timing cover is actively leaking. The leak itself is not super important. It's a call for early maintenance items.
> TIMER COVER(S) AREA:
-- Replace chain tensioners and CPS while around there.
-- Inspect "magnet" solenoids are still leaking free or not.
> LOWER ENGINE:
-- Remove Alternator (2 screws + 1 nut) and clean it well. Replace it's internal voltage "regulator/brushset" with OE part.
> LOWER ENGINE:
Excellent confirmation! Yea I mine as well do that all when it’s open. Makes sense to do so.
