M113 V8 Kompressor Platform Technical discussion relating to models sharing the M113 V8 5.5L Kompressor. Including SL55 AMG, CL55 AMG, S55 AMG, E55 AMG, CLS55 AMG, G55 AMG, SLR (M155).
HEADERS GOT CHERRY RED WITHIN 15-20 SECONDS
Old Jan 1, 2011 | 04:32 PM
jamusa's Avatar
I just swapped an E55 motor to a G55 motor,the car idle smoothe,and all connection hooked up correctly.The E55 was a kleeman stg 4(headers,tb,cams....180 pully,stall converter,LET tune)I transferred all these parts to G55 which fit perfectly.But upon start up within 15-20 sec when the car is held at 4k rpm to recycle the headers get glowing cherry hot.Any help,or suggestion would be very helpful.
Old Feb 28, 2011 | 08:39 PM
elijah's Avatar
Euro Cars Only
Yup that doesnt sound good.
I don't know if a lot of people visit this section of the forum so you might be better off posting this in the E55 sub-forum.
Best of luck resolving these issues
Old Mar 23, 2011 | 05:18 PM
Viet_Amg408's Avatar
Pinto
check make sure enough coolant, water pump or electric cooling fan coming on?
also look up oxygen sensor volts reading
if O2 sensor stuck in rich, during close loop operation. the computer shorten up the mixture to compensate for the supposed "rich" condition...therefore your car run lean.. pull out the spark plugs and confirm if its white color...
good luck
Old Mar 23, 2011 | 06:15 PM
danlnyc's Avatar
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
that sounds pretty cool! swapping e55 to g55 motor. Can I ask why you swapped?
