Data Logging
Data Logging
What data logging software is every one using? Pros and cons to different versions out there?
Many thanks!
Many thanks!
E55, Supercharged Z4 (sold)
Anyone use auto enginuity? It can scan via the OBD-II port plus it also has acceleration software. 60ft times, 1/8 mile, 0-60 etc looks like you could even use it for 60-130. It says "Speed vs Time graphing". $250
Dashdyno SPD does the same thing and maybe more. A bit more expensive but still not bad. http://www.auterraweb.com/dashdynoseries.html Don't have time to look into them right now but they looked like a do-it-all kind of device.
Any experiences?
Any experiences?
Any experiences?
Any experiences?
Wow. Thats awesome. Looks like that was during a 1/4 mile run. Is that right? I like that you get all the basic info in one package. CEL codes, engine data, and accel numbers. Does it do 60-130?
No, it does have some runs you could do but it wouldn't be accurate when compared to the performance box. Everything is done through the OBDII port when it comes to performance data and the output is way too slow. I think when monitoring 3 different parameters you'll maybe get up to 3 sample per second. This is why I opted to go with bypassing the OBDII and tapping directly into the source....instant info. If you take a look at my graph it will be obvious which parameter are still going through the OBDII, the lines that are really boxy. On these parameters I didn't mind if I got slower sampling.
I have the zietronix setup on my Buick with wideband O2, MAP, EGT etc. Are you able to get those parameters plus what you select? Or just some predetermined values? Is you MAP from a zietronix sensor or factory Mercedes computer info?
Thanks!
Thanks!
If anyone is interested in a setup like this call Rob at Needswings!
