Images/Diagrams of the M275 V12 Bi-Turbo
Does anyone have images or diagrams (good quality) of the engine?
Oxygen seems to have some really good ones in his signature.
Hey Oxygen,
In the S600 V12TT, is the IC plumbing part of the radiator, or on a seperate heat exchanger ?
If its not, can you make a resevoir with its own closed circuit heat echanger without extra heat from the motor ?
Thank you in advance.
seperate
you can still add a reservoir
seperate
W220 S65 AMG
Not a problem at all!
Let me know if you're looking for anything particular. I have lots and lots of technical drawings from MB, most are rarely seen on the public internet.
Ed P (02-03-2021)
Cool intake temp with your a/c unit ?!?!!
Has anybody ever seen this ??
Drops temp before intercoolers down to 55 deg F. WOW !!!! Thats what we need for these engines .Oxygen, what do you think ?
http://www.killerchiller.com/index.html
Take a look at the videos on the website.
Do you think that will work with this motor? What will be the hp gain if temps drop down another 50 deg ? There will be no timing retard and the cooler air will add huge power to the rear wheels. I would estimate about 25 rhp. What do you all think ?
ближний свет, регулировка W215 2003
Меня зовут Стефан, Украина. CL600 2003. Спасибо за рисунки.
Ближний свет - ксенон, лампы новые. Светит в низ, в дальней зоне темно.
Не знаю как регулировать. Может есть инфо или практика.
Заранее благодарен.
Заранее благодарен.
My name is Stefan, Ukraine. CL600 2003. Thanks for the pictures.
Dipped headlights - xenon lamps new. Shines in the bottom, in the far zone is dark.
I do not know how to adjust. May have info or practices.
Thanks in advance
Any more images of the other side of a running M275?
Hey Oxygen, do you have any images of the left side of a M275 in a '04 S600. I have one that I just added to my harem and it has this one vacuum line on the passenger side of the motor at the very left corner of the cooler that is just hanging in the wind. It was uncapped when I got it, so I believe it to needs to be connected to something. But I can't find anything to connect it to. Do I just need to cap it?
Is there a small chance that you have a vacuum line map or know someone that does?
The images that you posted are excellent.
Thanks Kendo
Thanks Kendo
CL65 AMG, RS6
Oxygen, Ty for pics, awesome and relieves a little of the intimidation factor.....I also own an Audi RS6, V8 cosworth TT...with terrable heat soak...I did install a 50/50 meth injection kit, a great addition for the $, what system do u run on the Mercedes? I am using Snow performance on my Audi.
