Oil in ECU / TCU Box?
So last night I took the cover off my ECU/TCU box on my '05 CL65 to check fuses, connectors etc and I noticed that there was quite a bit of oil in the bottom of the box that the ECU / TCU sit in.
It's light weight so I'm thinking it might be from the ABC system - does anyone know what oil carrying components run close / next to the electronics box that would have sprayed / collected in there?
I'm hoping it's not oil leaking someplace and traveling along the wires back to the box!!
I't due into the dealer Monday to swap out my IC pump (preventative vs dead) but wanted to see if you gentlemen had any thoughts?
Cheers everyone.
Luckily the oil is not electrically conductive.
I've tracked down 2 CL W215 part# for the connector near the transmission: O-Rings.
0269974148
0269974048
Is that all I need to swap out or do I need a new connector that connects near the transmission?
Also do I need to change out the harness connector that is at the end where the tcu box is?
I think the best route is to get a new inner connector with the 2 red o-rings, replacing it with a new designed one with 2 black o-rings.
I just took the tcu out of my CL65 and noticed that some oil is leaking from it similar to other posts here. I got the gearbox oil changed about 2000 miles ago - would this have anything to do with this??
With the old original part, Oil leaks past it and wicks up the wire harness wire(s) insulation..
Lots of models and even Chrysler models have had that issue occuring before they came up with the replacement part with better O-rings.
I think it's ok with alittle oil, but might be an issue if it over fills it.
I have yet to pull the TCU out myself..
How do I lift the fuse box to get to it?
I'm sure it'll be easy after the first time.
I recall it was a bit tight to get a hold of it and get it out..
I think the manual mentions lifting the fuse box alittle to get at it easiler.
Thx
after cleaning the TCU and putting it back flip it around and slide it in so the wire harness connector is on the bottom and not on the top of the TCU this will prevent fluid from going back into the TCU if it wicks up the wires again.
