V12TT Need Help with troubleshooting misfire codes
'05 SL65 AMG
Anyone have troubleshooting info for misfires? Seems all cylinders on right side have set misfire codes. If I clear the codes they are immediately reset. According to the part number on the coil pack is has already been replaced. I have had the car for about a month and today the CEL came on with codes P0300, P0301, P0302, P0303, P0304, P0305 and P0306. I suspect the ignition module, but wanted to test it rather then just through parts at it.
Thanks,
-Jim
Thanks,
-Jim
Its hard not to think its the coil since its the entire cylinder bank, I've had one side then the other a month later which was then replaced a second time along with the ignition module. In the end I think the ignition module may have shown misfires in both banks which was why it was replaced. There are a few part numbers on these coils. From what I was told they, were problematic and took a few redesigns to correct. You may want to confirm you have the newest part number not just one that wasn't original.
SL65 AMG, X5-4.8i M-Sport, 530D, 528i
It's most probably the ignition power supply placed between the two cylinder rows. I had the same faults as you, and MB changed the ignition coil, but it was the ignition power supply that was faulty.
'05 SL65 AMG
Well I ordered the coil pack yesterday. Hopefully that is the problem. I wasn't able to track down any diagnostic proceedures to test it.
-Jim
-Jim
'05 SL65 AMG
best price was parts.com, but they charged me $140 for shipping. bmwmercedesparts.com was a few dollars more and shipping is free. I didnt go with them becuase my last order took two weeks to be delivered and I needed my car back up and running. My other car needs a head gasket and was getting worse by the day.
-Jim
Posted from Mbworld.org App for Android
-Jim
