AC based heat exchangers
Line from pump to KC after heat soaked car, parked for an hour, then 3 mile drive getting into boost twice. Never got above 50mph, last mile in subdivision with two stops, backing into garage and checking temps.
Line out from KC.
Inter cooler
And for what it's worth, I am running the tiny little Johnson CM-30 pump. I mounted the pump to the killer chiller and they sit together in the HVAC air inlet box. The plumbing all stays behind the engine and in the cowl space behind the engine. I just put a 180* bent hose where the coolant comes out of the factory F hose that collects coolant from the intercoolers and fill pipe and routed it right back to the pump, then to the KC, and back to the stock Y going to the intercoolers. Here's the pump mounted to the KC.
It's nice that it's cool enough up there mostly year round that you'll rarely need A/C in the car. The problem is down here it's 100+ and humid in the middle of the summer. Black car with black interior, you can imagine, it becomes pretty necessary if you don't want to soak your seats with sweat. My Buick is set up the same way with valves to shut off either evaporator. Definitely handy to have the option. Does the killer chiller setup come with solenoids for that purpose, or do you have manual valves? I bought some solenoids to replace my manual valves but haven't gotten around to installing them.
Using the intercooler circuit should dramatically increase the performance of the A/C system when stopped/at low speeds, and the thermal load is pretty small compared to what the intercoolers pull out of the charge air so the heat exchanger should have no trouble handling it, especially since the presumption is it's mostly only taking on extra load when the car is stationary and the A/C is going full tilt. If I can find room to add a couple gallons of capacity somewhere, I would love to do that as well. The same goes for the chilled loop. I wish I could find somewhere to store an extra 5 gallons or so of coolant/water up front without deleting the windshield washer reservoir but that's unlikely, so I will probably have to run lines all the way to the trunk.
Hopefully I can figure out where the heck I put those solenoids. I would love to be able to shut off either core with a switch from the cabin. In fact, I consider that a necessity on the Mercedes...didn't care so much on the Buick (dark tint, light interior). I think I will put mine on the high side though, before the evaporator.
