M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
NITROUS ON V12
Old Sep 29, 2013 | 11:05 AM
jason3977's Avatar
04 E500 20in brabus monoblocks 1 serious 500E & 91 300CE 2JZ 2005 CL65
NITROUS ON V12
Has anyone ever tried this? Does it harm motor? input please.
Old Sep 29, 2013 | 12:05 PM
tc1728's Avatar
Unless you need the extra 0.5 to 1.5 seconds in the quarter mile, don't waste your time, money or effort. I had nitrous on my GTO and thought it was a waste of money.
Old Sep 29, 2013 | 12:09 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
small wet shot will help to keep intake charge cool
Old Oct 1, 2013 | 07:56 AM
jason3977's Avatar
Whats a small shot?
Old Oct 1, 2013 | 09:02 AM
TwinTurboTim's Avatar
2006 CL65
I would guess a small 50 shot would be worth 100 as it usually goes this way in turbo cars with small turbos. Cools the charge so much its worth more then what it should be.
Old Oct 1, 2013 | 03:58 PM
RaceHorse's Avatar
CL65
There is a guy who is on here from time to time, I think he still has the S600 record of 10.6x but he ended up shattering the rear and then moved on. From what I recall he made it sound as if it was a simple setup from a GM V8. If you have some miles on your car I doubt you tranny and rear will be real happy with it, but I'm sure it will make you smile in the mean time.
Old Oct 1, 2013 | 03:59 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
You would be better off running water/meth injection IMO.
R.K.
Old Oct 17, 2013 | 07:40 AM
Flight Test's Avatar
Buick T-Type, 70 cuda, S65 and a very FAST Truck!
I reccomend you contact Stephen04E55 he went 10.50's at 132ish on his S600 on the bottle. If you search his user name you can find lots of nitrous info.
Old Oct 21, 2013 | 01:22 AM
NRL's Avatar
NRL
CL65, FJ80, Sportsmobile 4x4, Model X Plaid
I was thinking about the 25 shot if there is one and then work your way up by changing the nitrous jet, but cooling it down sounds like a double benefit.
I think the hard part is the tedious work to work the braided gas line from where the bottle is in the trunk.. and hooking it up to detecting WOT to increase fuel flow.. when armed.
So where would the soft nitrous be before the intercoolers or after near where they merge before the air intake manifold valve?
Anyone have details?
Old Oct 21, 2013 | 09:13 AM
2006 CL65
Zex makes a kit that goes off TPS voltage. You could hook that into one of the APP wires. Not sure if there is an actual kickdown button or not. It also inputs RPM for a window switch.
Old Oct 21, 2013 | 04:08 PM
Benz-O-Rama's Avatar
I was there for this run. Had a baby seat in the back too.
He's the only one I know of that's run the gas on the V12s. He knows his stuff....
Old Oct 21, 2013 | 05:39 PM
shardul's Avatar
there have been others too who have sprayed on the M275 TT. They started off with a small shot and then got greedy. Some pics of the damage
Old Oct 21, 2013 | 05:40 PM
RaceHorse's Avatar
CL65
What about Renn......never mind.
Old Oct 21, 2013 | 10:42 PM
radride's Avatar
Thats a very expensive motor to destroy.
R.K.
Old Oct 21, 2013 | 10:51 PM
Shifter's Avatar
E55, SL63, ML550
Im curious how much was greedy ?!
Old Oct 22, 2013 | 09:40 AM
shardul's Avatar
yes very expensive.
if I remember correctly it was over a 100 shot.
Old Oct 22, 2013 | 10:01 AM
2006 CL65
Are the rods different on a 6.0 vs 5.5?
Old Oct 22, 2013 | 01:44 PM
NRL's Avatar
NRL
yes very expensive.
A 25 shot or 50 shot should be fine..
I had a soft Nitrous added to my Honda during my college years and it wass a hoot.. 12.5 sec quarter miles, Corvettes and Talons for lunch.
...then I got greedy and went 75 or might have been 100 shot and broke the valves, but before that, it lasted for years..good balance, then I broke it but had used it everyday back 20+ years ago.
It was relatively easy to pop the shot nozzle out and put in a different size jet nozzle.
All in all, I think it's a mute point since the V12's are heavy and really hard to keep the wheels from spinning.. Only usage I would think is more for cooling or getting more at speed...
Old Oct 22, 2013 | 05:09 PM
greekviking's Avatar
2007 s600
Really ?!?!
Is it worth destroying your motor for a few tenths on the quarter mile?
Seriously...
These engines are too expensive to fool around with. Not worth the effort going this way. Only knocking the door to trouble.
To each their own-whatever makes you happy I guess.
Old Oct 22, 2013 | 06:36 PM
NRL's Avatar
NRL
Originally Posted by greekviking
Really ?!?!
Seriously...
Your right.. probably shouldnt' be done on a CL65.. but maybe for people picking up the cheaper CL600 deals..
I have the ECU/TCU tune on my CL65 and probably won't do it.
Old Nov 2, 2013 | 05:28 AM
02cl55amg's Avatar
CL65
Why else would you run nitrous!?!?....... it was the gto that was the waste of money...
Would have never done it on my cl65(that car was too precious), but I did pick up a cl600 and am tempted to squeeze on it. I'd rather spend $500 on a nos kit than mess with a trunk resovoir......again. Don't want to hit it with anymore than 100 shot. I figure my 600 runs low 12's stock, so prob mid 11's modded. Like to see 10.8@127 on the spray. My 65 only saw 10.9@126.
Tempted to do:
Ecu/tcu
Exhaust
HE/pump
50-100shot
I've pmd stephen and has told me he never had a hiccup while running the 150shot on his 600. Ran a basic ls1 kit, with hand held activation button. He didnt spray in 1st and let off the nitrous between shifts. Not sure how/when he busted the rear end.
Old Nov 8, 2013 | 10:26 AM
shardul's Avatar
don't they make a kit now with a smaller fuel cell in the trunk so you don't have to mess with the factory fuel line to run a wet shot.
Old Mar 9, 2015 | 08:56 PM
Dr Matt's Avatar
05 CL65
Hmmm....... a 50 shot or a Killer Chiller.......... or..... both???? I should probably go through the trans first. Dropping .5 in the 1/4 would put me about where I'd like to be. For now.
