M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Engine Rebuild/Crank Pulley Vibrating
Old Apr 6, 2014 | 08:15 PM
matthewschauble's Avatar
2003 Mercedes S600
The serpentine belt flew off my 2003 Mercedes S600 with 145k miles when I was driving. At first, I thought it wasn't going to be a big deal and that it probably just needed an idler pulley. However, the mechanic said that the crank pulley was vibrating because the crank pulley bolt was loose and caused it to strip. He said that caused the crankshaft to get messed up inside the engine. He said he either needed to take apart the front of the engine or replace the engine altogether. Both of those options cost almost as much as the entire car is worth. I had the B Service done at a Mercedes dealer, and I feel like they should have recognized the problem as part of the inspection. I also had the water pump replaced recently at an independent shop.
I'm looking for any advice you all may have on this matter. Has anyone seen this kind of issue before? Copart said they would buy the car for $1600 as-is which would be an enormous loss for me. Do you all have any better suggestions as to what I should do?
Old Apr 8, 2014 | 10:07 PM
TwinTurboTim's Avatar
2006 CL65
I think more info would help. Is the crank snout bent or just the threads stripped. If they are stripped that should be easy fix. If crank snout is bent your screwed.
Old Apr 9, 2014 | 02:41 PM
BI-Performance's Avatar
Former Vendor of MBWorld
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
We have handled this a number of times now. First, get a pic of the crank snout and pm me. Dont worry just yet, there are a number of things to check and perform before you throw in the towel and say you need a new crank.
