I don't think this is normal so I am going to do a full coolant flush but wanted to see if the temp gauge should be right in the middle and stay there or does it fluctuate slightly?
Mine fluctuates a little. I think the Thermostat opening is lower than the fan switch on temp so you may see it cooler at times depending on HVAC settings, outside temp, and other factors. I never really watch coolant temps on my digital gauge, usually keep a closer eye on IAT & oil temps. I do see my oil temp in the 215* range at times, and others it is around 205, so with varying by 10* that I'd expect there to be a similar variation in coolant temp.
You can see those things on the digital cluster? I have never seen a menu for that. Let me know if that is aftermarket or oem.
Thank you!
Thank you!
Aftermarket. It is from my Aeroforce interceptor gauge mounted where my ashtray used to be.
