M275 AMG Vacuum line question
Note: this is not my engine, mine is in the car, found the image online from speedriven
I read about the function of this in WIS I believe.
Cheers
The intercooler has compressed air in it during an in boost situation! Thus the pressure (compressed air) from the intercooler is routed to the wastegates for the turbocharger. The bypass valves get vacuum from the vacuum reservoir under the intake manifold which gets vacuum from the intake manifold itself from a nipple of the back of the intake manifold. I own a SL600 and have more hours under the hood of it to count.
Obviously, the vacuum connection has to come from downstream of the throttle.
Nick
Read about it in page 68, here;
https://web.archive.org/web/20060508...2008-06-03.pdf
Divert Air Control system purpose is to reduce charge pressure when throttle is released.
My thoughts;
It looks more or less like the same system as wastegate but this time to bypass
the compressor wheel (as opposed to bypass the turbine wheel of the exhaust part
that the wastegate does). And, while the wastegate can be in a partially open/closed
state, the Air Divert will be either on or off?
br,
syljua
