M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Scratchy sound around oil ventilation valve
Old Apr 28, 2020 | 03:42 PM
pillowshot's Avatar
2007 CL600
Hi all,
Been trying to figure out a noise that's coming from the left front camshaft area, specifically around the plastic oil separation valve that sits on the timing cover. You can find a video of the sound here:
I was talking to an S65 owner who had a similar-ish issue which was the centrifugal oil separator that sits just inside this timing cover, and I changed this as a precaution to no success (old one had some cracks in it so it was a good move regardless).
Does anyone have any idea what this sound could be?
It is definitely not belt related and can be heard with a stethoscope only at the timing cover where the black plastic valve mounts - basically I think the noise is coming from the camshaft but can't figure out what it is.
If any other M275 owners could have a listen to their engines in this same area I would be interested to know if it makes a similar sound. It only makes this sound when warming up. When the engine is hot it is very quiet.
Thanks all
Old Apr 30, 2020 | 05:42 PM
pmercury's Avatar
member
CL
Originally Posted by pillowshot
Hi all,
https://bit.ly/2VLzXkg
Thanks all
seems nobody has the answer
I have had all kind of noises on my V12 engines
but need a better recorder to give it a try
can you do that ? I have studio monitors on my pc
Old Apr 30, 2020 | 07:53 PM
pillowshot's Avatar
2007 CL600
​​​Hi @pmercury
Thanks for chiming in. Unfortunately there aren't too many folks about the V12 board. I'll try to get a few more recordings.
Old Apr 30, 2020 | 08:21 PM
pmercury's Avatar
member
CL
​​​Hi @pmercury
To bad for them
probably a problem of not having the skills or cash for maintaining them
personally I am in total love with the MB V12
Old May 2, 2020 | 02:04 AM
JohnLane's Avatar
222 S-65
To bad for them
I also have the sickness.
OP post up a video of the noise. 'No video found' per uncle Google in your original post.
Old May 2, 2020 | 02:11 AM
pillowshot's Avatar
2007 CL600
Link updated. Thanks!
Old May 3, 2020 | 07:49 AM
pillowshot's Avatar
2007 CL600
New video with the belt removed. Here you can hear it clearly from around the 48 second mark to the end.
Old May 3, 2020 | 08:46 AM
pmercury's Avatar
member
CL
sound as bearing bad to me
Old May 3, 2020 | 09:24 AM
pillowshot's Avatar
2007 CL600
It does a bit but I don't think there are any bearings it could be.
Old May 3, 2020 | 09:53 AM
pmercury's Avatar
member
CL
here if you don't have it yet
https://mega.nz/file/NapxUBTS#GgFAvN...6fF9QJQPuEacoU
Old May 3, 2020 | 04:09 PM
pillowshot's Avatar
2007 CL600
Have got this, thank you.
Going to try a slightly thinner when cold oil. Have ordered some 0W40 to replace the 5W40 that's currently in there. Seeing as the noise all but disappears when the engine is hot it may be oil flow connected.
