M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Can a bad ignition pack cause engine not to rev up?
Old Sep 4, 2020 | 02:25 PM
George993's Avatar
2014 E350 Wagon, 2009 SL550 no ABC
Hi, my 2007 S600 has misfires on cylinders 1,3,5 so it looks like ignition cassette. But the cassette was changed together with the plugs 4 years ago and has low mileage on it (voltage transformer has also recently been changed) One of the additional symptoms is that occasionally when the engine is started up, it fails to rev above the idle regardless of how hard the accelerator is pressed. The car just refuses to move at all.
Is it possible that a computer disables power/revs due to misfires caused only by the cassette?
Or is it impossible and there is some other problem at play? DAS/Star shows no other errors of any type. I've been looking at all of the actual values of everything I could find (including the throttle body parameters) and they all appear fine. There may also be a small valve cover gasket oil leak, if it matters (not enough to drip under the car). Thanks!
Old Sep 5, 2020 | 03:42 PM
George993's Avatar
Old Sep 6, 2020 | 10:00 AM
Paul Shalom's Avatar
E400 W207 C320 W203
LOL..for what exactly??
Old Sep 6, 2020 | 12:38 PM
turbonos7's Avatar
'05 S430, '05 S600
The OP's question was on the title of the thread so @Plutoe answered with a simple yes. Is it not clear?
Old Sep 6, 2020 | 01:40 PM
E400 W207 C320 W203
I see.
