M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
nonexistent coolant hose p/n? (back of engine)
Old Dec 1, 2024 | 07:01 PM
JustTXn's Avatar
2005 CL55 AMG || 2005 CL65 AMG || 1989 560SEC
Question nonexistent coolant hose p/n? (back of engine)
Hello,
Had a lovely coolant hose blow on the back of the engine while driving today. I cannot find it in any mercedes illustration, but it runs from the right cylinder bank to the left side of the car, located right above the transmission bellhousing. I have found an image of the hose as-is on the back of an engine auction image image- any clues? I've looked at MB rad/cooling/heater core hoses, all with no success.
Any input is appreciated.
Old Dec 1, 2024 | 09:45 PM
JustTXn's Avatar
Couldn't stop thinking about this, so I crawled on top of the engine with a mirror on a stick... Part number 2208325094! Attaches to the heater core junction thing (plastic, ew) at the faux-firewall fiber barrier thing. Might as well flush and replace that before it breaks as well.
Old Dec 3, 2024 | 10:32 AM
tim687's Avatar
CL 600 '00 5.8L V12
I think that the hose is visible in EPC, but at the AC/heating subsystem, not in engine cooling subsystems
Old Dec 10, 2024 | 11:49 AM
JustTXn's Avatar
You are correct, I found it there after finding the part number... Unfortunately the diagram as a standalone gives little reference to how hoses connect to the engine or anything not explicitly involved with cabin heating or cooling.
Old Oct 2, 2025 | 02:30 AM
Jtaveras13's Avatar
2015 e63s
Any other things I should change while I'm changing the hvac heater core pipe
Old Oct 2, 2025 | 10:17 PM
JustTXn's Avatar
maybe the plastic y-pipe that hose connects to, it penetrates to the other side of the fiber separator behind the engine... I don't trust plastic after it's about 20. Replace your expansion tank too. I've seen a few crack and blow all the coolant out.
Old Oct 6, 2025 | 10:37 AM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
Here is the EPC image for reference, under "83 Heating and Ventilation > 180 Heating water connection"
