Battery Protection - warning comes on only while driving
1 Post
2013 E 350, 2012 GLK 350, 2012 C300 4matic
For about 4-5 times this week the malfunction indicator comes on after driving anywhere from 5 - 15 minutes. It clears after about 5 minutes. No problem prior to start or at start - everything working. For me it's more than an annoyance as my Radar/Laser system is tied to that circuit. Anyone have any ideas before I bring it in ? Maybe a particular fuse ?
Any advice would be appreciated.
Honda Accord
Remove any aftermarket equiptment before you bring it to the dealer. They can easily blame you and your aftermarket equiptment without their having to investigate further. Even if they investigate, they can always blame and charge you and how could you possibly verify whether that is the case or not. You still might get blamed (and charged) even if you remove the equiptment if any wiring has been modified.
William
2003 E 320
William
2003 E 320
Honda Accord
Hopefully, the problem is related to the recent recall regarding updating the battery control software. There have been reports of people having battery problems if the car is not started nearly daily. I haven't heard anyone yet that has had the recall performed. My last post was kind of negative; this one is more optimistic. Try posting your question or searching the the E-Class W211 forum.
William
2003 E 320
William
2003 E 320
2005 W169 A150
Still not had my recall letter.
1 Post
Calum - is it on startup or after driving a while ? The frequency picked up yesterday and is back down again today. I had it in the past on startup and then it would clear - they had replaced some module - so it"ll be back again after a call tomorrow.
2005 W169 A150
1 Post
Calum - Are you planning on taking it in ? I left a message with the Service Boss and told him I'm going to bring it in. I'll let you know what the outcome is - my feeling is not software but rather a module that controls the monitoring of voltage.
2005 W169 A150
I'm living with it for now, but might raise it again in a few weeks.
1 Post
Calum - Got it back - they changed out a defective battery control module (internal short) part # 211-540-69-45. It's a part connected to the battery (main) in the trunk (boot?). they also ran some tests (draw test) overnight to make sure. So far sems fine.
