Installing McCulloch HIDS but wont stay on need advice.
2)
hookup with problems.Both of these could have been answer by using the proper forum search function prior to implementation. Yes, this may sound harsh; but you are the one who wanted to save the $s.
Make sure you mount your resistor to a good insulator like plastic. That way the heat will form a protective shield, keeping the dirt out, around your component, by reforming the plastic around it due to the heat. :v
Is this true for my 2002 ML320?
Thanks in advance.
Pete
Thanks in advance.
Pete
Does it make any difference in how HID kits draw power? I seen some kits draw power for the ballasts directly from the battery...and the lowbeam sockets are utilized as the ON/OFF trigger.
Then there are some kits that pull power for the ballasts directly from the lowbeam sockets (no hookup to the battery at all).
Does one or the other counter the need to have the ecu "switched"?
Btw... my dealer service rep said he's checking into it...not sure if I need to do it, but thinks that if I did need to do it, it will cost me 1.5 hours.....roughly $165 to switch the setting.
Pete
Some kits comes with wiring harness that connects the ballast directly to your battery, with the stock halogen connection used to trigger a relay to turn on/off this connection. While this is the preferred method, it will not work with your MB as it needs to see that 35watts power going through so the "lamps out" error is not triggered.
