Spark Plugs - Open Discussion
http://www.boschusa.com/AutoParts/Sp...PlatinumPlus4/
Hoping to generate some discussion about spark plugs… So, what do the rest of you use and why do you feel your plug of choice is best?
Sooner of later you will have problems such as rough idle or high emissions.
The proper plug is Bosch H9DC (NOT the HR9DC resistor type), and these are not commonly available at McParts, but are readily available for two bucks each from Mercedes parts specialists like Fastlane.
Any spark plug with an "R" in the designation is a resistor type and should NOT be used.
The issue is not "platinum" versus conventional copper core plugs. It's resistor versus non-resistor and Bosch Platinums HAVE RESISTORS.
Take a look at the service CDs. They have several examples of both normal and anamolous of secondary wave form traces and show at least one with excess secondary resistance. It may not result in any noticeable difference when the plugs are new, but as they age - wear and build up deposits, the number of misfires will increase resulting in more idle roughness and higher emissions than if the proper non-resistor plugs are used.
Bosch H9DCs (for M103 engines) cost about two bucks each and have a normal service life of 30K miles. The H9DC0 has a "heavy duty" electrode. They were OE, but they are more expensive, and the standard electrode H9DC work just as well over the 30K service interval.
Spending more money to by the WRONG plug is just plain foolish!
Your explanation, at least at face value does not make sense… at least from my electrical engineering background. The most important point aspect of the spark plug is to create an arc at the exact instant the engine management program stipulates. An electrical arc is created by “jumping a gap” with a very high voltage potential. Not trying to insult your knowledge, but only wish to reiterate the plug’s purpose.
A resistor-type plug CAN cause a degradation of current flow at the very instant of spark generation – this is true. As we all know, this is the basis of resistor plugs in the 70’s to greatly reduce the infamous radio “static”. Today’s electrical systems are far more immune and non-resistor plugs can be used with confidence and a clear radio. But my engine does seem to perform better with the Bosch 4-electrode version.
So what’s the big deal with the Bosch four-electrode model, resistor or not? I believe the four electrodes do provide a higher chance of the spark arc occurring precisely when the engine management program wants it to. Four times as much, per spark event. If, for example, the “primary” arc gap has (for whatever reason) a resistance, there is another gap that would arc. You are correct in that only one gap is used at a time, but the gap path could be different for each arc event. One could argue that the timing difference is miniscule, and I would agree. But if the spark itself IS more consistently timed correctly, the engine overall would run a bit better/smoother. This logic is sort of portrayed in my personal findings over the last 6 months. Again, I am NOT saying the Bosch 4-electrode plug is the perfect plug… only that my data indicates a bit better performance.
Perhaps after 50K miles the plugs may deteriorate faster than the standard plug. For me at least, I may never get to that point, as I would change the plugs at the 30K mark. Not sure why, perhaps it’s simply from my old small block Chevy days with 4-barrel carbs.
Regardless, I will be changing out the Bosch 4-elctrode plugs this week in favor of fresh MB plugs. I also have a set of slightly used MB plugs, but I am unsure of how many miles are on them.
Thanks TresX and mleskovar for the thoughts, and I would be interested to hear more of your opinions/thoughts, as well as others.
"Fine wire" electrode plugs - usually "double platinum" - both the center and fine wire ground electrode can be advantageous in high performance engines with marginal ignition energy, but this harks back to the days of mechanical breaker points. Modern electronic systems going back to the seventies have at least double the per spark energy of breaker point systems. I've seen plugs come out of mid-seventies GM products with HEI systems where the center electrode was worn nearly to the insulator and you had to measure the gap with a ruler, but the engine basically ran fine. When you have a "fancy" ignition system, you don't need anything more than a plain vanilla two-dollar spark plug.
So conventional electode plugs work very well with modern ignition systems. These Bosch Platinum plugs that are heavily advertised and sold at McParts are junk and defy every theory of ignition and flame propagation because all those ground electodes are a HUGE heat sink to an incipient flame, so there are going to be more misfires, which eventually means rougher idle and over the limit HC emissions.
Measure the wire resistance on your engine, all will be about 2K ohms regardless of length. My understanding is that the wires have discrete resistors that are part of the spark plug terminal, so the wires themselves probably have very little resistance. It's also my understanding that the cap has resistors - about 1 or 2K ohm - built into each cap terminal.
Mercedes implemented a unique solution to the RFI suppression requirement. Rather than using conventional resistor spark plugs and RFI wires they have discrete resistors built into the spark plug terminals, cap terminals, and require non-resistor plugs to achieve the design secondary voltage wave form.
If you use anything other than Mercedes OE equivalent spark plugs, spark plug terminals, wire, or cap you're asking for trouble.
As far as where is all the documentation for all of this? Get a subscription to Star magazine. They have an artilce almost every month where the technical editor writes of how these platinum plugs are NO GOOD!
Anyhow, this will be my last ditch effort to convince you. I appreciate your background in electrical engineering and I'm sure you're a very intelligent person, but from my experience with "AUTOMOBILES" you are incorrect.
Honestly, if you needed open heart surgery would you go to a surgeon or a micro-biologist?
For the benefit of others reading - at a mere 1,000 RPM (a little over idle), each plug is firing over 8 times per second. At modest highway speeds (well, at least in California) my engine is near 2,500 RPM, which equates to each plug firing over 20 times a second. That’s a lot of heat being generated and being absorbed by the plug’s electrodes. One could debate that the extra mass of electrodes may assist in keeping the plug cooler under highway conditions. Regardless, I want to research the heat sink thought some more.
Because my engine has distributor-less ignition, I do not have the traditional high-tension wire found on most engines. Instead, I have coil packs; one per spark plug. However, the concept of the coil pack is identical to that of traditional distributor engines, just without the mechanical aspects of distributors. I have always been curious about what EXACTLY is inside the infamous coil pack. May go to a junk yard, scavenge an old one and tear it apart. I would like to see what amount of resistance is in the short high-tension connector, as well as the energy coil itself.
As for whether the over-advertised Bosch plugs are junk or not, I can not say… yet. One must admit that MB way over-emphasizes the concept of using ONLY Mercedes-Benz parts; that all other parts are inferior, cheap, junk and will cause problems. Remember when synthetic oil first came out? No auto manufacturer would sanction it. Now MB demands it. (Granted, synthetic oil has improved over the years.) It all hails back to the advertisement picture of the MB Engineer hunching over with a migraine headache at the instant someone in America used a non-MB part.
TresX, I’m not trying to convert you or change your mind, or anyone else. I am merely seeking different thoughts from different people; sharing ideas and concepts – nothing more. True, I am not an automotive engineer. But I have far more years of automotive experience than perhaps you give me credit. I also do not subscribe to the MB-only parts philosophy simply because the marketing folk in Stuttgart say so. This is why I want to see/experience different aspects and not accept blindly what the OEM says. If my experiences prove to be not as good as the OEM, then of course, I will follow the OEM's recommendation. Also, I have been a member of the Mercedes Benz Club of America for many years and have all the back issues of the Star since I joined. While I do not recall a specific article in the Star regarding different spark plugs, I will look for it. In the meantime, thanks for the discussion and your thoughts; sorry we cannot continue it. Any thoughts from others?
I'm not saying that these plugs are completely worthless. Just not what is intended to be used in our vehicles.
Yes, I remember them all, and you are correct - there is a lot of junk out there. But innovation comes through different thoughts. And we must think for ourselves, not through corporate eyes. If memory serves me, the infamous flexible fan blade was an after-market success before auto makers adopted it as standard equipment. There are good ideas out there; we just have to separate the good from the bad.Yes, the discussion is on resistor vs. non-resistor and multi-electrode spark plugs. I'm still researching and it may be that my research shows the resistor to be more of a liability than the gain by using multi-electrode. Who knows, I may be an innovator. Then again, I may be chasing the spark plug version of an "Intake Tornado". But it is fun to challenge the traditional thought and "think outside the box". Thanks again for your thoughts and the great thread!
As for the gap, my weekend experience proves you correct. As part of the research I am doing in spark plugs (see above), I removed the Bosch Platinum+4 plugs and reinstalled the spark plugs sold to me through the MB dealer in San Diego. Well, some interesting things were discovered…
First, the dealer SOBs in San Diego sold me the wrong plug!!!! I plan to post later more on the spark plug change experiment that is currently under way in my V12. This detail will be fully outlined.
Second, I found the gap was WAY off on every single plug… by the same amount. The owner’s manual clearly stipulates a nominal spark gap of 0.032”. All 12 of the plugs sold to me through Mercedes, and installed in my car by Mercedes, were set just under 0.040”. Folks, that’s 20% off!
The point is that the car ran quite acceptably with the 0.040” gap from San Diego to San Jose. Even gave me reasonable gas mileage, etc. Obviously, the electrode gap is not as critical as in days long passed. I have since abandoned the notion of spending an inordinate amount of time painstakingly trying to make the gap perfect.
Kestas, I do not believe it is important for street engines to have plugs with needle points. The spark arc will occur across any two metallic points – one with high potential; one with ground. No electric field at the spark plug is needed for automotive spark generation. In street applications, the spark is not required in an absolute, precise location; such as a needle point. In fact, if the plug did have needle-like points, I would think they would wear very quickly – arcing is a destructive process.
0.032" / 0.040" = .8 = 80%
There is a 20% difference between the two amounts; the wider gap is 20% wider than the smaller gap. Math aside, I was truly shocked that they ran from San Diego to San Jose with a gap this wide. It really blew my current thinking of spark plug gap out-of-the-water. Just dawned on me that the statement could be read a different way... No, the spark plugs were not 20% off their price. (Wish they were!)
Kestas - I was taught that the filing flat of the center electrode is more for cleaning than "flatness". The spark plug, as we all know, starts to foul with combustion stuff. If the center electrode starts to become covered with deposits, then it makes it increasingly difficult for the spark to be achieved.
The gap is spark plug dependent for each application. Different plug types and brands have differing electrical and physical properties. I've seen the recomended Bosch plugs come pre-gapped at .032 while the recomended NGK are .040 for the same application.
Also, do not try to file or sand any plug except a standard copper electrode. You will damage the exotics and create hot spots. Filing a used plug would expose some fresh copper making the plug perform like new. Same goes for gapping. Be very careful not to damage the platnium/palladium/irridium/etc. electrodes.
By the way, is this the first plug change for your 98 E320 with 103Kmiles? I hope you can get the plugs out OK. I have an 03 E320 and I changed my plugs at ~50K miles because I heard too many horror stories of plugs seizing up in an aluminum cylinder head at the 100K change recommendation regardless of the plating put on the plugs to stop this from happening. While I was taking the plugs out, they were all squealing -- glad I changed them.
Good luck and don't forget the anti-seize paste and the dialectric grease too.
Regards,
paul...
Regards,
paul...
I've been in enough auto supplier facilities and met enough smart people in the industry to appreciate the kind of engineering that goes into each part on a car. Regardless of the "boners" that have made their way onto vehicles (I blame management and bean counters, not engineers), spark plug choice is not something that can be easily botched.
Regards,
paul...
