steering rubbing noise
2001 E430 Sport
Good Morning All.
Any ideas of what could be cause a "rubbing" noise when I turn the wheel? not to loud but definetly noiticable.
now if only this icon made a rubbing noise
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
S500/W220/2000
Power steering often makes sounds -- not sure if the "rubbing" sound you hear -- especially when cranked all the way to one side or the other. Sure it isn't just "normal" sounds you are hearing?
Originally Posted by RickyE430
Not normal for sure. Seal in the rack huh? That sounds complicated. You guys think I should be really concerned?
there is a rubber boot on the steering shaft on the engine side of the firewall that tends to make some squeeks, use a small hook, and pull down on boot, and apply a little grease to it internally, and this very well could take care of your problems
