AMG engine timing
Old 06-04-2006, 02:14 PM
SMARTSSUCK's Avatar
AMG engine timing
I recently replaced a head gasket on a 104 engine, I have done many of these jobs without a problem however this engine was an AMG 104. The only difference I could see was the displacement but when the customer drove the car he said he noticed a lack of power compared to before I replaced the gasket. Can anyone tell me if the timing is set up differently for the 3.6 litre 104 as opposed to the 2.8 litre.
Old 06-04-2006, 06:43 PM
MBTech21's Avatar
05 ML350, 85 300D
Sounds like you have one cam off a tooth, but that should set a check engine light (car will run fine), but if all marks are lined up- is it an AMG gasket (too thick would lower compression).
Old 06-04-2006, 08:41 PM
SMARTSSUCK's Avatar
head gasket
I had thought of this, however, when I compared the old gasket to the new one I made sure the cutouts that represent the sizes on the side of the gasket were the same.
Quick Reply: AMG engine timing
